Question about Webroot Spy Sweeper (spysweeper) for PC
Sweep stuck / unable to get Firefox to run
Sweep still going after 9 hrs
IE now runs Firefox won't even after several attempts to download
  • 327 Answers
Re: Sweep stuck / unable to get Firefox to run
You should reboot into Safe Mode to run these tests. Restart your computer and tap F8 while its rebooting. From there, it is easy to do all the anti virus and other scans. You can also download Hijackthis from here with IE.
A word of caution though: It will display all processes that your computer has, so you have to look over the list and see what doesn't belong like web browser helpers and other known spyware. Tips: Always use Firefox when possible, use your anti virus program once a week, try Sbybot Search and destroy. You can see what is running on your system by Ctrl+Alt+Delete. One of these should be stopped. You can also go to Start---->Run---->type " msconfig " and enter. Here you can stop or change programs that run at boot up. You can post any results on here if you need further assistance.
Posted on Nov 19, 2007
0 characters
3 Points
Were do I locate a download for IE 9?
just google internet explorer 9 and download from windows/microsoft
Jan 05, 2012 | Computer Utilities & Maintenance
Webroot spysweeper won't sweep
This sounds like the program glitched. Try removing it and reinstalling. Then have it check for any updates.
Aug 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
I had a similar issue and I could not fix it even after several attempts. I called
The Best Pc Doctor Team and they fixed it for me.I happened to know about them on
the internet.Their support was wonderful.I am including their contact details here.
877 407 9229(Toll free)
Aug 26, 2011 | Symantec Norton Internet Security 2011 1...
Uninstall not working for System Suite 9 on Vista 64 bit system
I had a similar problem with a different program a while back. I came across Revo Uninstaller and found it very useful to fix my problem. Try for the free version, see if it helps.
Apr 18, 2010 | Avanquest System Suite 9 Professional Full...
IE error message, closes when entering an address
I always use Firefox as these problem never happen and it is free program and easy to download.
but to answer your question, go to IE and in tools select internet options and delete all temp. files and files stored on your computer. You may have some cookie that is causing the problem. Other causes may be a virus. but first do as I suggested and restart your pc. at any rate. here is the link to download firefox
Dec 05, 2009 | Computer Utilities & Maintenance
Webroot full sweep gets stuck on one file and then freezes. can't shut-down webroot or computer.
Okay, before I can start full troubleshooting, I need you to turn your computer off, then turn it back on, while it is loading BIOS I need you to tap F8 Then load safe mode, then I need you to log on the account labeled administrator. Then attempt to run it, then tell me the result, so I can being troubleshooting.
Ryan Frame
Creative Energy Associates Technical Center
Aug 01, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Adobe Reader Crashes My Browser
Firefox has an extension you can add to browser that might help you. Go to FF addon site (under tools) look under extensions, downloading will install to browser. Then try to install reader while in FF.
Hope this works for you.
Feb 01, 2009 | Computer Utilities & Maintenance
Adobe Reader 9 problem
I would like to help you to quickly solve this problem. Yes, you will need to install an add-on that will allow you to view PDF files in your FireFox browser. Follow these instructions.
1) Go to 2) On the navigation menu at the top, click on "Add-ons". 3) Next, in the text field where it says "search for add-ons", type "Adobe reader". 4) The add-on is named "PDFescape Extension". 5) Then click on the green button "add to firefox" located to the right of the add-on name. 6) A pop-up window will appear with the name of the add-on, in this case "PDFescape Extension". 7) Next you will see the "Install" button located at the bottom of this pop-up window, click it to install the add-on. After this, the pop-up window will close and open a install window. 8) In this download window, you will notice the progress of the download. When it is complete, you will be prompted to restart firefox. To do so, simply close the firefox browser window, and then start firefox up again. 9) To test the add-on, try viewing a pdf file in the firefox browser.
That's it!
I hope this helps. Please let me know if you have any questions.
Thank You,
Jan 24, 2009 | Computer Utilities & Maintenance
Spysweeper wont sweep. pls help
this sounds like spyware in the registery download any spyware removal tool and run this offline then run your antivirus program and see if this gets rid of the problem if this still exists then save all files and emails out and re-install operating system.
this is all I can give help with.
Jul 08, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Spy Sweeper won't sweep
I have seen this problem a couple times. The only fix that seems to work is uninstalling Spysweeper and then reinstall it again. If you go to start>Programs>webroot you will see an uninstaller. Run that, reboot the computer, then reinstall again from your install disc.
Jun 04, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Webroot Spy Sweeper (spysweeper) for PC Logo
105 people viewed this question
Top Webroot Computer Utilities & Maintenance Experts
Michael Thomas
Michael Thomas
Are you a Webroot Computer Utility and Maintenance Expert? Answer questions, earn points and help others
