Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 will not turn on. Power light blinks on/off 3 times. After a bit of web searching I found that I am getting a 19 error code. What does that code mean?
  • RCA Master
  • 8,617 Answers
19 error means Chassis not detected. Chances are its the flyback and the cP150 and CP114 capacitors which usually cause that error. You can get the 259296 Flyback repair kit which contains the parts and detailed instructions on CD at the following link under RCA kits.
http://www.tvrepairworld.com/
Posted on Jul 19, 2009
    Problem Solver:
  • 5 Answers
I have a 52 inch RCA d52w20 tv with the same problem.. The solution or a bandaid to this.... Turn the tv off, take the back off the tv get some rubbing alcohol and pour it around the base of the FLYBACK (IF YOU DONT KNOW WHAT THIS IS GOOGLE FLYBACK AND IT WILL SHOW A PIC OF IT) on the board. Use a blow dryer and dry what has not evaporated and wait 20 mins make sure the board is dry and plug in.... Contact cleaner might work better but alcohol is on hand.... dont know if it is one or the other but if you use both it should come on no problem..
    Champion:
  • 230 Answers
Capacitor on power supply need be replace.
2200uf 16V ( upgrade to 35V), 220uf 35V,
Resolder all connections under fly back.
Thank you
Posted on Aug 07, 2009
My rca d52w20 it is showing the 19 code. the light is coming on and off 3 times. After severar intents it turn on. Help, please
Very common problem usually caused by CP150, CP120 and CP114 capacitors on the deflection board. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com which also includes the instructions for the repair.
May 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
When the power is turned on I get no picture or sound. I get a sound like it is trying to power up and the power light goes off it doese this 3 times and shuts off
The power light on the front of the set should blink when the power turns off. The count of the blinks is a code for the problem. Give this code to an RCA service center and they may be able to help.
Mar 29, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a rca universal remote control also a cody dvd player.
Hi freeent316,
Unfortunately, the RCA 15-2104 does not have a code for Cody brand DVD players. The list of codes can be found at the following web address:
http://support.radioshack.com/support_video/doc67/67141.htm
Since there is no published code for Cody brand devices, I recommend using the CODE SEARCH function. Here's how:
1) Turn on the DVD player
2) Press the DVD key on the remote
3) Hold down P until the red light blinks twice
4) Press 9-9-1 (the red light will then blink twice).
5) Slowly alternate between pressing the DVD key and the POWER key - when the device turns off, that means the remote has found a code for the DVD Player and should then operate it.
You can read the details about the CODE SEARCH feature in the user manual, which can be viewed at the following web address:
http://support.radioshack.com/support_video/doc66/66339.pdf
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Radio Shack 15-2104 Remote Control
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not power up
the flyback error is usally the power led will blink three times when power is pressed then go out. does your set do that when the power is pressed one time?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not power on light blinks 3 times
3 blinks is the code indicating that the flyback is bad. You need flyback 259296 you can get a new one at the following link
http://servicemanuals.vstore.ca/
Jun 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,724 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
