Question about Hotpoint Dryers
Error code F-10 - Hotpoint Dryers
  • 240 Answers
Un plug the appliance. Remove the back cover of the drier, you will see the heater bracket.
un screw this from the back panel. You will see three thermostats at the top. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click sound.
This procedure would reset the thermostat and you can use the drier again
Posted on Jul 19, 2009
  • 3,230 Answers
Error code F10 means that the heater and or thermostats are faulty.
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Good Luck!!
thanks
System error in designjet 500 plotter error code 20:10
The error code 20:10 does not appear to be a valid error code. The plotter may be misinterpreting the code. Try disconnecting the service station (power off). It is the bundle of green wires plugged into the small interconnect board behind the display. You will need to remove the right end cover to see it. That should generate a 21:10 error when you power up. You will need to hold down the top cover interlock. If you get the 21:10, reconnect the service station cables and disconnect the cables going to the ink supply station. When you power up you should get a 22:10 error. If either of these causes the 20:10 error, that module has a problem.
Oct 03, 2013 | Office Equipment & Supplies
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
Dvd error code 10
Cause of the Code 10 Error A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
The safest thing to do is to perform system restore or
run SYSTEM RECOVERY.
If you will use sysem recovery it fix all the problem of your computer however all files on your hardrive and softwares that you installed will gone.
It will be back from original manufacturer settings just like the same thing you got your computer.
Dec 30, 2011 | Sony VAIO S360 Notebook
It gives code 10 error. device can not start
HI
A Code 10 error is generated whenDevice Manager can't start the hardwaredevice, a situation usually caused byoutdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. Inother words, a Code 10 error can sometimes be a verygeneric message indicatingsome kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is alikelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driveror restore the system on previous date..
regards
sandy fixya
Jul 18, 2011 | Lexmark International Lexmark X422
Error code f9-10 and f6-80
while printing showing error 10
Mar 23, 2010 | Office Equipment & Supplies
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Why does my Frigidaire electric slide in range keep beeping and showing an error code F-10. Model # CPGS389EC
    F 10 error code is not listed on my error code sheet and in my experiance error codes not listed are internal controlboard error codes and the control board should be replaced.
    Jan 07, 2010 | Kitchen Ranges
    I have a dv9700 with error code 10.
    found this website which explains the error code 10 problem, hope it helps...
    Jan 02, 2010 | HP Pavilion dv6000z Notebook
    BJC-8200 beeps 10 times and wont go online.
  • Hi
  • All The Best: Pineworks
  • Oct 06, 2009 | Canon BJC 8200 Photo InkJet Printer
    Pc will not start. showing error code 10.
    Sounds like a Driver error code what operation system you using?
    Apr 26, 2008 | Computers & Internet
    Dryers Logo
    126 people viewed this question
    Top Hotpoint Dryers Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
