SOURCE: outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
SOURCE: Bose link AL8 connection problems
I had a similar problem, though intermittent, using my 48 with the AL8 and room-mate speakers. I kept getting a "no signal received from media centre" message on the remote in the second room.
Assuming that the batteries are ok and you don't have a hardware problem, the problem might be that the 48 is not picking up the signal from your remote control in your second room. The signal from your remote control is a radio signal that goes directly to the 48 - it doesn't communicate via the AL8 receiver. I think the orange light will only turn green once a signal is being transmitted from the transmitter unit plugged into your 48 media centre, and this won't start transmitting until the media centre gets a signal from the remote telling it to switch on.
The aerial for all the remote controls is contained in the power cable that links the 48 lifestyle unit to your VS-2 unit. Make sure that this is uncoiled and oriented vertically, as far away from other cables as possible.
If this doesn't work, you can get an antenna extender that plugs into the RC socket on the back of the lifestyle system. Again, orient this vertically. You can get these from Bose.
Is there anything in the wall that might be blocking the radio signal? Lots of metalwork for example?
If orienting the power cable from the VS-2 doesn't do the trick, I suggest that you go to a local Bose shop. (An actual Bose shop, not just an electrical or hifi store stocking Bose products). I explained my problem and the tech guy gave me an extender gratis (its basically just an FM aerial wire by the look of it). I installed it this morning and, so far, its seems to be working ok. As my unit is fairly new, he also offered to have the kit back in the shop to check it all out and, if that didn't work gave me Bose technical support number. He even offered, if all else failed, to send a guy out to my home to get it working - and I didn't even buy it from there!
Hope this helps.
SOURCE: remote control not working (no functions),
Do the contacts look ok?
you can check if it is working by looking at it with a digital camera
press a button on the remote
if it shows as flashing on the digital camera screen, then you know it is transmitting.
then your problem would be either the device you are trying to operate is not receiving, or the remote is using the wrong code.
if the code is wrong then look it up online. there are some helpful sites that tell you the codes and how to program the remote.
good luck!
Testimonial: "Great help its pushed me in another direction"
SOURCE: Vtech Kidizoom camera. Have changed batteries but
Don't use rechargeable batteries. Use Alkaline batteries. Rechargeables run at 1.2Volts each. Regular batteries run 1.5V. The camera wants 6V. Using rechargeables, you're shorting the camera by .8Volts. It wont turn on because it thinks the batteries are low and is protecting the pictures in memory. Use regular batteries, you'll be ok and your kid will love you again.
SOURCE: A/C won't kick on w/
Okay it seems that for some reason the battery change scrambled the brain of the t-stat... that happens...
To fix it you will now have to go into the "Installer Menu" and reset the paramenters of the t-stat.
If you have the Installe brochure then you can look in there and then set the tistat for "heat/cool" and also to "auto fan" and then to "auto changeover" These should get you back to cooling again...
No big problem, just a small programming issue...be patient and if you do not have you book don't worry... you can look it up here...this tip tells you where and how to find any of the Honeywell t-stat manuals.
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
