Question about Kenmore Dishwashers
Kenmore elite double drawer dishwasher leaking from top drawer. I also have a problem with gasket on side of dishwasher breaking. I've already replaced twice in one year.
  • 5 Answers
SOURCE: Fisher and Paykel dishwasher double drawer problem
Hi there FM, Your Dishdrawer is it intergated or does it have a factory finish on it? This will help me ask the next question? Kind Regards Carmen
Posted on Aug 09, 2007
Master_Tech
  • 770 Answers
SOURCE: Double Drawer Dishwasher
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
Posted on Jan 22, 2008
  • 125 Answers
SOURCE: Kenmore elite dishwasher
If this is a rounded cover you need to use a flat blade screwdriver. Make sure the screw is out on the lt side, then insert the screwdriver on the rt side where you see the tab/slot. gently press the screwdriver to the rt to pry the cover out. The chopper will come out easily, going back in is tricky. Use a 1/2 inch open end wrench, compress the spring and insert the wrench between the blade and the screen, then put the chopper back in.
Posted on Jan 31, 2008
SOURCE: Kenmore Elite Dishwasher 16939
I have the same model dishwasher with same problem. The gasket first came loose just after my warranty expired. The stainless steel and heat don't make for a good combination with the glue that holds the gasket in. My husband works with caulk and the like. He found a clear gel of some sort to get everything to adhere. It's had to be reapplied. I just make a habit of making sure the gasket is seated in its track and watching if dishes on top rack catch the gasket when I pull rack out.
See www.repairclinic.com, item #1065754, White silicone adhesive, specially formulated for use in the dishwasher to adhere tine tips & door gaskets. It's an accessory for this dishwasher. I don't know if Sears Parts Direct offers it. Sometimes their price is lower.
From above website it costs $14.55
Posted on Jan 08, 2009
iwillfixforu
  • 619 Answers
SOURCE: lights do not come on kenmore elite dishwasher
There is a thermal fuse on this model located on the control board. Remove control panel and you will see it attached to the board with 2 wires going to it. part number is 8193762. Hope this helps.
Posted on Feb 24, 2010
My kenmore elite grab n' go fridge model number 795.72063.112 has frost build up behind the drawers how do I remove the drawers to get rid of the frost so my door will slide closed all the way???
There are little tabs that need to be pushed in on both sides of the top drawer with a small screw driver. Be careful as they may break! Drawer will pull all the way out to then access the next drawer.
Nov 07, 2017 | Kenmore Refrigerators
Why wont the top[ drawer on my Kenmore elite dishwasher open all the way ?
Is that the one with the high-quality slides with ball-bearing glides? If so, then you probably have to replace the bad glide assembly. If it's the kind with the plastic rack adjusters with the plastic wheels, then 1 of the wheel hubs has probably broken, and you would need to replace the adjuster. Probably should order 2, because the other side will probably break too.
Sep 27, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Inlet bezel located in l/hand outer side of dishwasher is leaking can't get it off the dishwasher to see if it is it or the gasket
The inlet/outlet bezels are defective. If you run the dishwasher wthout them in place, you get water in the drawer door and all over the floor too. The plastic disintegrates. It's a problem that Kenmore/Sears needs to fix asap!
Nov 01, 2009 | Kenmore Dishwashers
Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Jun 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Nov 11, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step
5
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Jun 08, 2006 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
696 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
