Question about KitchenAid KUDR25 Dishwasher
Door won't open. only had 2 months - KitchenAid KUDR25 Dishwasher
  • 163 Answers
Call kitchenaid get replaced
Posted on Jul 26, 2009
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
2003 Honda pilot right rear door lock won't open from the inside only
It can be faulty switch or safety lock enabled.Go through this direct link and follow the step by step process to get the door open from inside:
Click the ;link:--
http://www.howtorepairguide.com/2013/02/honda-pilot-rear-door-lock-wont-open.html
This will help.
Thanks.
Feb 15, 2013 | 2003 Honda Pilot
2000 Chevy S10 passeger door won't open
Remove the door panel and inspect the latch rods for damage or broken retention clips. A video is below of how to remove the panel.
Nov 06, 2012 | 2000 Chevrolet S-10
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
92 Honda accord drivers side door won't open. And
IF DOOR WONT OPEN FROM INSIDE THEN IF YOU LIVE UP NORTH RUST IS PROBLEM.....TAKE A FUNNEL POUR BRAKE FLUID WHERE THE LATCH IS....WAIT 1-2 DAYS AND DOOR WILL OPEN.....SHORT TERM FIX
May 23, 2012 | 1992 Honda Accord
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Aug 04, 2011 | Whirlpool Inglis IP8200 Dryer
I have a Maxx Classic WAE20261AU/01 front loader. The machine won't start because the door won't lock. The door has been playing up a bit for about 2 months, but now it won't lock at all. It is...
Sorry. It seems that I have fixed it by using your solutions!
I drained it and cleaned the filter thing down in the bottom right hand corner, put it back to gather and then it turned on again!
Interestingly I found a bobby pin down there!
Thanks for your assistance John_Cross!!
Jun 21, 2011 | Bosch Washing Machines
KitchenAid KUDR25 Dishwasher Logo
123 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
