Question about Bionaire Dryers
Where can i get a replacement 3 blade propellar? for a high velocity air circulator fan?
    President:
  • 1,952 Answers
Www.thefind.com/.../browse-high-velocity-industrial-fan use this site
Posted on Jul 19, 2009
Blade won't move unless you manually spin it to get it started
I would check to see if mtr. has oil ports,if not oil mtr as best you can..Check for bad capacitor..If still having problems replace mtr
Dec 12, 2015 | Comfort Zone CZ700T 20-in High Velocity...
I need A 9 inch fan blade for my Massey fan 9
Did you contact the manufacturer or manufacture's fan replacement parts center?
If you're thinking of having one made, I'm sure it would be far cheaper to replace the entire thing, (or maybe find a similar fan and use its blades so they are more balanced).
Or try ebay.
Sep 25, 2014 | Dryers
Polar Aire 20 In. 3-Speed High-Velocity Floor Fan on off switch wiring
i need an on/off switch for my utilitech 20" high velocity floor fan model # LF-20MCA
Mar 26, 2012 | Dryers
I need to replace the fan blade on a discontinued lakewood 18" high velocity fan but they are no longer available. I searched on the Lasko high velocity fan and found that I can purchased a blade for...
Hi I did some research on shaft size and length with no results. Use a tape measure and measure across the end for that measurement, and the length. You can then find out the size of the prop you have found to see if it will work. You can also take your prop down to any appliance parts house or even a small electric motor repair shop which have prop/blade's hanging on there walls they can match you up with. This is your best choice as you need to have the blade pitch be the same also, or the fan will be out of balance and either blow less or to much air if the blade pitch is not correct. I replase blades day to day on a/c units and large fans, and I have a tool/gauge to lay on a blade to get the exact pitch which is very important. If it is a little different, it will change the amps on the motor if its pulling or pushing to much air due to prop pitch, causing motor over heating and failure. This is just for your information. I hope this has been of some help to you. I hope and wish you the best. You can contact me for any help you may need to come. Thank you!
Shastalaker7
A/C Contractor
PS, Please rate me for any help I may have been. Thanks again.
Jun 07, 2011 | Heating & Cooling
How many watt it have?
    Features and Benefits:
  • Powerful 3 speed turbo fan for fast focused cooling power or enhanced air circulation
  • High performance blades rotate for maximum air velocity through the wind tunnel turbo grill
  • Pivoting head can be adjusted in a 90 degree arc for varied air distribution
  • Versatile design makes this fan great for use on desk and table tops
  • Wall mounts with separate purchase of hardware
  • Equipped with a carrying handle for transport
  • Dimensions and Weight:
  • Size: 6.33" x 11.375" x 11.125"
  • Weight: 3.5 lbs.
    Power 50W @ 110V
    Power 60W @ 220V
Feb 14, 2011 | Honeywell HT-800 Table Fan
Need new motor for Patton High Velocity Air Circulator Model G-1272, 110 current. After about 27 years, the motor quit. This fan is a wall mount behind my wood/coal stove facing the stove pipe. It has 3...
Do you know where I can get a replacement knob that goes on the back for low, medium and high setting? It came off when I was moving and is difficult to turn without it (i use a screwdriver at the moment).
Jan 11, 2010 | Patton (HASF1016UC) Stand (Pedestal) Fan
I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Sep 28, 2009 | Dryers
Dryers Logo
212 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Steve F
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
