SOURCE: vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
SOURCE: water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
SOURCE: i have lost manual could
Ok, go to www.vax.co.uk and when you bring up their web site, click on the large Support box at the top, this will lead you right to how to download a manual. I just did it, it was easy. You can type in the model no. or click on the carpet cleaner photo and it will easily lead you to the manual. take care and good luck, Andy
SOURCE: I need an instruction manual for a Vax Rapide
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
