Question about Dell Ethernet Card Network Adapter
Ethernet connectivity problem.
I have the same problem of connectivity going in and out. My router is connected to the wireless adapter and then to it is connected to the laptop. In this case the ethernet cable is not detected at all and it displays a notification that the ethernet cable is unplugged.
When I tried to connect the modem directly to the laptop, it displays a notification that the ethernet is plugged in and then within a second it will display that the ethernet cable was unplugged and it keeps going back and forth with these notifications.
PS: I know the wireless router works because I can access the wireless internet on my other laptop.
Any help would be appreciated, Thanks in advance.
K
  • Anonymous Mar 29, 2014
    i installed win7 and now i cant connect to the imternet with a simple ethernet cable. Why? No driver. VAIO laptop 64bit E Series vpceh18fg
  • 66 Answers
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Right-click Local Area Connection, and then click Properties.
  3. On the General tab, click Configure.
  4. In the resulting dialog box, click the Advanced tab.
  5. In the Property list, click Media Type or Link Speed & Duplex or something similar.
    Note If these properties do not appear, look for a property that has the values Duplex and Half-Duplex.
  6. Click a specific bandwidth in the Value list, and then click OK.
  7. Close the Network Connections dialog box.
  8. Test the network connection.
  9. If these steps do not resolve the issue, repeat steps 1 through 5, and then click a different value in step 6 until you have tested all values.
Check if that works.
Posted on Jul 28, 2009
How do I connect my pc to my router? There is no ether port in the back. Can it be done thru the sub?
There are more ways how to connect PC to router in your case.
My assumption is that your PC has no Ethernet port.
  1. Use wireless connection. Activate Wi-Fi card in your PC and connect it to router by wireless network.
  2. In case you do not have wireless router or you prefer cable link you can buy an USB Ethernet adapter.
Some examples:
Anker USB 3 0 to RJ45 Gigabit Ethernet Adapter Supporting 10 100 1000 bit...
Cable Matters SuperSpeed USB 3 0 to RJ45 Gigabit Ethernet Adapter in Black
Jan 20, 2016 | Computers & Internet
What is the difference between USB Ethernet Extender and a USB Ethernet Adapter?
Extender boost your wireless connection range.
Adapter is use to connect to a wirelles connection (router)
So let say you have a router far from your PC the extender boost your adapter range to get the router best signal
Jun 07, 2013 | Computers & Internet
Motorola 1c743 wireless adapter reset
You modem needs to be powered on, linked to your cable or phone connection, and then linked to your router with an Ethernet cord. You also need a base computer (connected to the router with Ethernet as well) to adjust your router settings, like password and router name, and assure that you are communicating with the Internet.
Install your wireless adapter software to your laptop or computer that will be using the Internet wirelessly.You will be prompted at some point during the installation to plug in the adapter. (If prompted, restart your computer.)
Plug the adapter into your computer or laptop. Some adapters come as USB-compatible (Universal Serial Bus) plug-and-play devices, and others are PCMIA (Personal Computer Memory Card International Association) cards that go into a special wide slot in laptops.
Go to your computer control panel and click on Network Connections when the software download is complete (if the control panel does not load automatically). Your new adapter should be now be listed. Select the icon and look at the description to make sure that it is connected. If not, right-click the adapter icon and click Enable.
Double-click the adapter to search for a wireless connection. Refresh the list of connections available until you find the name of your router. Enter any passwords that you set up for your wireless router and then connect to the Internet.
Apr 07, 2013 | Motorola Computers & Internet
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
Ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
Jun 02, 2009 | NetGear WGR614 Wireless Router
Unable to connect Linksys wireless router to my arris cm450a
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
Toshiba Satellite ethernet port disappeared...
I think you have answered your own problem, your wireless has possibly been zapped.
To test your ethernet adapter on your laptop connect it to a network hub, check the hub and see if you have a link light on the hub and or laptop..
To test your wireless router, connect it to a known working computer with a network card and check the router configuration, using the browser, if you cannot access it then its zapped.
Jul 08, 2008 | Toshiba Satellite A105 Notebook
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Dell Ethernet Card Network Adapter Logo
480 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
