Question about Bushnell ® HOLOsight
Sighting the Bushnell Holo Sight
I just bought an AR-15 rifle with the Bushnell Holo Sight. In my first round of shots, I created a tight grouping about six inches to the right of center on the target at 50 yards.
HOW do I adjust the Holo Sight to shoot six inches to the left at 50 yards?
Or, if you have a Link where I can FIND the instruction manual, I would appreciate it.
  • 86 Answers
Here is were you can download the manual
http://www.retrevo.com/support/Bushnell-51-0021-manual/id/8328bh538/t/2/
Posted on Jul 29, 2009
How to use redfieeld 3x9x42 scope
Depends on the scope and rifle type to which it is attached.
I invested in an inexpensive laser bore such as this one for an AR: SightMark AccuDot Laser Bore Sight - 223 Model SM39001 (for AR-15)
Once the scope is mounted properly, and assuming you have not made any vertical or horizontal adjustments, set the rifle on a stable platform, insert the bore sight, point it at a target 50 (rimfire) to 100 (AR) yards out (works best in low light situation).
Once you have the laser centered on your target, make elevation and windage adjustments as necessary placing the scope cross hairs over the laser. Remove the bore sight and fire 3 rounds, then fine tune elevation and windage.
Dec 27, 2014 | Optics
Need a manual for my 1st gen Bushnell holo sight
Contact Bushnell,if you can't find one on line.
Nov 11, 2012 | Bushnell Optics
Bought a 444 Handi Rifle with a Bushnell 3200 firefly scope on it. Tried to sight it in at 75yds yesterday. I adjusted the elevation up 6 to 8 "inches" and I am not noticing any change. Still shooting low....
O.K Your gun packs a good kick, but you might try to first, tap the scope with the handle of a fair sized screw driver, after each adjustment. Next do not adjust it so many clicks at the time just 3 clicks and see if she moves the point of impact. Try a few clicks and tap the main shaft of the scope kind of rap it then shoot for group, fair 2 rounds to see if it has settled down, then adjust a few, tap and fire. work slow with a older scope and try to stock up on the bullets you decide to go with and zero for them. Any other round you use do not zero, but use go old windage to pratice with.
Oct 26, 2009 | Bushnell Elite 3200 Firefly 3-9x50 Matte...
I aser bore sight my Bushnell banner. I need to
if it is verry tight back it off a little bit you dont want to break the seal.i have never been a big fan of the laser bore sighters.i have had a cpl and both were inaccurate.BSA makes a good bore sighter for 49 bucks.try a cpl shots with it and find out how far you are truely off.remember 1 click is 1/4 inch.in 100 yrds.in the army we had all the ammo we needed to sight our rifles in.but here in the real world with ammo prices so high a good bore sighter is the way to go.
Oct 19, 2009 | Bushnell Velocity Speed Gun
How do you sight it true for the rifles prior to using the windage and elevation turrets. All other scopes I,ve seen with range compensators have the ability to be sighted in. I can't figure out how to...
You can get a base line by bore sighting the scope. Bore sight kits are a bit pricy, might be best to take it to a gun range an start at 15 yards shoot a few move out to 25 the 50 then 100. Yes your scope should be sighted for one gun one round, with a cold barrel. Let it cool between shots.
Oct 14, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
I can shoot my centerpoint scope on my .22 and it
When adjusting a scope just move a few clicks at the time, after every few clicks tap the scope with a screw driver handle. Fire 2 rounds for group tap and fire the third round it should be in line with the 2. Keep that up till on target. Let the gun sit till cold and re-fire for grouping, 2 rounds, wait then the third. To keep shooting round after round can get the reciver warm enough to wedge the scope in its bases, causing your problem.
Oct 13, 2009 | Optics
I have a Bushnell Elite 4200 6x24x40 rifle scope 42-6242M
First is to try for a group, do not adjust the scope in any way. Shoot 4 rounds with out adjusting the scope. The gun should settle down and start to group. If you can not get a group in 6 rounds go clean that gun & check your ammo. Start over. If she does not group, its the gun not the scope. Once it starts to group move the cross hairs in the opp direction small clicks and "TAP' the scope after each adjustment. Shoot for a group each time 2 rounds should group. Get a target that has a grid to help get on faster.
Sep 20, 2009 | Bushnell Elite 4200 6-24x40 Riflescope...
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
Bushnell holo sight
It will test the condition of the batteries. Turn the sight on to its brightest setting and leave it for 2-3 minutes. Then while looking at the red dot, press the battry icon button and hold it in. If the image does nothing, you are good to go. If it starts flashing, then you have less than 20% left in the batteries.
Jan 13, 2009 | Bushnell ® HOLOsight
Bushnell ® HOLOsight Logo
1,174 people viewed this question
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
