Question about LG Vu CU920 Cellular Phone
How can i put my music in music player? to continue play this
Sansa e250 dispyaying synchronize to continue music subscription
If your music has DRM it willonly allow you to sync once. they want you to repurchase the music. Try syncing music that is DRM free. If the new file work that is your problem.
http://www.sansaworldmp3.com/
http://www.sansaworld.com/
Apr 04, 2009 | SanDisk Sansa e200 MP3 Player
Synchronize to continue your music subscription
The "synchronize files to continue" is annoying, and you are likely to get it again. If the music files on your player came from Rhapsody, the short-term solution is to re-synch the files through Rhapsody itself. If your subscription to Rhapsody, Overdrive, etc. ever expires, you will also get this message. The only long-term way around this problem is to only load songs that are in mp3 format (Rhapsody has an Mp3-Only subscription, which is different from its regular subscription; Limewire is another choice - but it is prone to have viruses, and some ISPs will cut off your broadband if you use the service). If you wanted to erase all songs and start over from scratch, you could update the firmware on the player - it will have the side effect of erasing everything on the player.
-Tha Mp3 Doctor
Feb 14, 2009 | SanDisk Sansa e250 MP3 Player
I ran into the same problem with my Sansa when listening to legally downloaded audio books from the local library. This is what I found:
  • " Are you sure the player is in MTP(plays for sure) mode when you transfer it? You can check by going to settings>usb mode on the player itself. I think it needs to be for you to use library files like that. " (This worked for me)
  • "are you copy and pasting the files? if so you will need to use WMP to sync the files. copy and paste might not be transferring the license." (didn't try this -- didn't need to)
Hope this helps.
Nov 26, 2008 | Audio Players & Recorders
Won't play music
you must resynchronize to rhapsody and renew your Rhapsody subscription
Jul 09, 2008 | SanDisk Sansa Clip MP3 Player
please use the windows media player 10, click on sync and put all the songs you want in the sync list then click on start sync and it should sync properly without any problems.
Have a nice day!
tc
Jun 13, 2008 | SanDisk Sansa c200 MP3 Player
it's asking that you verify the DRM status (i.e., that you bought it and it resides on YOUR computer.) It cannot play the file until you synchronize it with windows media player. You can delete them off of the MP3 player just by noting which songs don't play and deleting them through windows explorer when the player is connected.
Mar 25, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My music is not wanting work Mp3 m250 2.0GB
use winamp to sync with his player or just about nay other.
Mar 14, 2008 | SanDisk Sansa m250 MP3 Player
Sandisk Sansa Clip MP3 Player problem
The songs that are on there were probably taken from the Rhapsody music service, or some other subscription music service. You must continue/renew the subscription to be able to continue playing them on the Sans clip.
Feb 26, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e260 MP3
change the mode of the player to MSC from Mtp MODE AND SEE
GO TO SETUP AND ENTER usb MODE AND SELECT msc I THINK THAT SHOULD solve your problem
Jan 24, 2008 | SanDisk Sansa e260 MP3 Player
What does "synchronize to continue music subscription" mean
the best way to put music into the mp3 player is by using windows media player 10, click on sync and put all the songs you want in the sync list then click on start sync and it should sync properly without any problems.
Jan 23, 2008 | SanDisk Sansa c200 MP3 Player
LG Vu CU920 Cellular Phone Logo
53 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
