Question about HP Compaq Presario C762NR Notebook
Compaq presario C762NR notebook pc I have trouble charging it, the blue light turns on and off. Once I plug it in I need to move the charger around in order to start charging
  • 11,896 Answers
You either have bad wires or loose connection. Take the prongs on the plugin and bend them both outwards. Use wrench if needed. Bend them just enough so they will stay in the outlet without being loose. This is the most common problem with charging
Posted on Jul 19, 2009
Replacing inverter on Compaq Presario C762NR Notebook PC
Here is the manual for your model laptop. Information regarding the inverter (HP Part # 454915-001) and how to disassemble and replace the part begins on page 55.
Thanks, and have a great day!
If my solution helped you, please don't forget to leave positive feedback!
Aug 29, 2011 | HP Compaq Presario C762NR Notebook
My compaq presario 2200 wont boot up...when i press the on/off switch without the a/c charger (battery alone), the amber led flashes twice....if i plug the charger in with the battery, the led blinks once...
If the computer is not turning on, there is a big chance of hardware failure and normally there is no easy fix for this rather than a motherboard replacement.
May 03, 2011 | HP Compaq Presario 2200 Notebook
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
I got COMPAQ PRESARIO C762NR NOTEBOOK PC AND I NEED 2 UNLOCK THE PASSWORD
Start up in safe mode (hold F8 at startup) and login as administrator. Go to start menu, settings or control panels, users and remove the password on the account you are wanting to access.. Then restart.
Sep 09, 2010 | Compaq Presario 700 470024-192 Notebook
Power cord will not light up where it is inserted into the laptop unless you hold it steady. It will not charge unless it is held in a certain position. Is the male part on the cord bad or is it the female...
You'll need to get another power cord that is identical in power and polarity and plug. One can buy a generic power supply from Walmart that will power most laptops or Radio Shack (Walmart is probably cheaper).
Once the new power supply is obtained, try it, and if the same thing happens, then the problem is in the female plug connection to the motherboard of the Compaq Presario C762NR Notebook.
The Notebook will have to be disassembled and the female plug connection to the motherboard will have to be replaced.
If the male plug end shows any fraying or excessive bending signs, then I would definitely replace the cord.
It is difficult to determine which is bad, the male or female part without changing the easiest part... the power supply.
Also, you could go to your local Compaq dealer and ask to plug in one of their power supplies to your computer and tell them the problem that you are having, determining which is bad, the male or female part of your power supply.
Good luck on this repair.
Aug 17, 2010 | Compaq Presario C762NR Notebook
My Compaq Presario CQ60 charger will not charge
try diffrent charger or try to turn on ur laptop with out the battery might be a problem with charger or battery
Aug 16, 2009 | HP Compaq Presario CQ60-249US Notebook
Burning
The motherboard in your laptop is overheating badly if its melting chargers but more importantly its not charging at times as well. Both symptoms relate to a bad motherboard. Try getting it replaced if you can.
Aug 03, 2009 | Compaq Presario M2000 Notebook
Compaq Presario 2200 won't hold a charge - on or off AC
I have a Compaq Presario 2210US. The wireless toggle button is in front on the right side, slightly under the top of the computer. Feel for it with your fingers or use a flashlight. It glows a bright blue when on.
Oct 30, 2008 | HP Compaq Presario 2200 Notebook
DRIVERS
Found someone with the same problem he solved it and posted the page here
http://www.xaqdesign.com/c762nr.html
Just follow the guide and you will be good to go
Hope that helps
Let me know if it solves your issue or if you need more help
Scanss2k
Aug 21, 2008 | Compaq Presario Notebook
HP Compaq Presario C762NR Notebook Logo
212 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
