S
Samwel John Posted on Oct 25, 2016
I don`t have photo/videos but what i know is the case of fuser unit error. SO how can i solve it.
5 Related Answers
Anonymous
  • 417 Answers
  • Posted on Jan 20, 2008
SOURCE: sc error 380 and fuser breakdown
Hi there you will need to replace the development motor but first try the following.
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and protected print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
Method 2: Press the “Up/Down arrow” keys together for about 5 seconds, then
press the “Enter” key.
The above message shown in the illustration appears on the display.
NOTE: The machine automatically goes off line when you enter the service mode.
Using the up down arrows select Engine and enter by pressing enter or # key.
Using the up down arrows select mode 5 then enter using enter or # key then select 810 (SC reset) press enter then if you want to select 809 (SC Detection ON/OFF) Enter and select 1 to disable. Escape or return key all the way out and exit. Turn the machine off then on again and test if the same problem then replace the Dev unit if still having the problem then replacement of the motor likely. I can email you the complete service manual if you like.
Thanks J
Anonymous
  • 417 Answers
SOURCE: SC380 and fuser unit break down
features
Thanks J
Anonymous
  • 417 Answers
SOURCE: fuser unit breakdown error sc380
features
Thanks J
Anonymous
  • 4 Answers
  • Posted on Mar 30, 2008
SOURCE: fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
A
Anonymous
  • Posted on Jun 17, 2009
SOURCE: CL7000 Replace fuser unit type G error
Run SP7-804-9
If you don't know how, or what that is, then you'd better call a service depot.
I will not post or discuss service mode procedures with end users, because you can create a great deal of problems if you're unsure what you are doing. (No offence)
How to Solve C 3502 error code in konica Minolta c 6100 1100 1085 6085
The C 3502 error code in Konica Minolta c 6100, 1100, 1085, and 6085 machines is related to the fusing unit. The error code indicates that the fusing unit is not heating up correctly. There are several reasons why this error code might appear, including a malfunctioning thermistor, a broken fuser heater lamp, or a damaged fuser thermostat .
A video: how to solve C 3501 3502 3503 3504 3505 3506 error in konica minolta 6500 6501 6000 7000 - YouTube
Turn off the machine and unplug it from the power source.
Remove the fusing unit from the machine.
Check the thermistor and fuser heater lamp for any damage.
Replace the damaged parts if necessary.
Reinstall the fusing unit and turn on the machine.
If the error code persists, it is recommended to contact a Konica Minolta service representative for further assistance
Error 010 110
It quite sure what you've done. But .... Looking at your photo, you have a page stuck in the fuser. ( you could see that I'm sure) remove the fuser and check the sensor flags. If you have an. Old fuser unit you could use that as a guide.
Good luck.
1helpful
I have IR 4570 error code E0000001-0002 i am reset this function this but this will not solve please help me
If you have resr the error code in service mode and it did not clear.... Odds are you are going to have to replace the upper fuser heating unit with a new fuser film or you may want to replace the whole fuser unit..... The heating element is shorting out...... Good Luck
11helpful
2answers
I got 02-000 error on samsung scx-4623f . How can I fix it?
This error is a fuser malfunction. You will need to replace the fuser unit in order to get this running again. A fuser unit will run about $90 for a refurbished unit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
I faced error ##322 on my fax canon L250 how can i solve this problem. What is this mean how can i solve it.
Error 322 means that your fuser is not heating. For most cases it means that you have a bad fuser module, and needs to be replaces. Send your unit for servicing at any Canon-approved servicer.
Lexmark T644 920.16 Service Fuser Error What do I need to do to repair this problem?
Lexmark gives the following list of all fuser errors and recommends what action you should take (Lexmark Knowledge Base). that the fuser unit failed to reach the standby temperature.
  • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
  • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
  • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
  • 920 Fuser Error message indicates that the fuser unit in the printer is below the proper temperature for printing.
  • You may need to replace the fuser: watch this video:
    http://www.youtube.com/watch?v=RjQkR4x9fqw
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    2answers
    The cannon coppier iR2016j is displaying sytem error E007. How can this problem be fixed?
    This is a fuser unit issue. Generally the fuser film has tracked to one side and is not centered like it should be. Fuser unit replacement is generally needed or in some cases the film itself can be replaced by a professional. Both jobs will require a professional service technician.
    7helpful
    I Cannot solve SC541 Error in RICOH Aficio 270
    It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
    5helpful
    "922 SERVICE FUSER ERROR"
    920, 921, or 922 Fuser Error:
    The printer thinks the fuser unit is not heating up to the correct operating temperature. This can be due to a bad fuser lamp or possibly no power getting to the fuser unit. As a customer, the only other thing you can do is to check the connections on both the fuser unit and where it goes into the printer. Make sure neither connection is damaged. If you are a technician working on the printer, you can check the voltage coming off the system board and Low Voltage Power Supply (LVPS) to make sure power is getting to the fuser unit.
    Don
    k24674
    ADMIN Andrew
    ADMIN Andrew
