That sounds a bit far-fetched. There are boosters and amplifiers that can increase wifi range omnidirectionally (within a radius), but a satellite dish would form a more or less focused beam in a narrow beam. If you wanted to send a signal from your home to that building, a dish may well work, and since the beam can be directed specifically at the building, it would be harder to intercept and hack the signal unless you were sitting in the path of the beam. Satellite dishes work in the Gigahertz ranges, so albeit there may be some loss of signal since the dish may not be tuned to the exact frequency of the adapter, if the power level is acceptable, the boost factor of the dish focusing the beam should overcome most of the loss caused by a frequency mismatch.
SOURCE: how do i download songs from my directv to my computer
Do you have a separate Internet Service Provider or does Direct TV provides the internet access ? Songs from Direct TV are usually of different format and compression so I doubt that it can be downloaded to your computer even wirelessly
SOURCE: I am not able to connect through internal
Locate the wireless switch and turn it on? if it is on you might need to reset the modem from your service provider. Just go and hit the reset button on the modem or turn it off completely. Power it up again and make sure that the switch is turned on if you have one for this lap top some are automatic.
The switch is usually located on the left or right front of the lap top housing in the front or on the keypad. You may have to push the FN key if the key is blue highlighted. Hit FN and press the wireless key if applicable. Make sure all is on and switched then reset the wireless modem or connection.
