Question about Hampton Bay Heating & Cooling
Model kc-25y1 my green cool dry light the gets the air going isn't switching over
2 Suggested Answers
  • 1033 Answers
SOURCE: rudd air conditioner isn't cooling,blowing
Hello, first check if the outside unit is running, if it is then check filter to make sure it is clean and that the blower wheel is clean and not dirty. If the unit is clean then most likely you have a low refrigerant charge due to a leak and will need a hvac tech to come out and fix the leak.
Posted on Jun 19, 2011
Furnace switches to auxiliary heat while in cool
It's likely a bad tstat. Turn the power off to your air handler. Remove red , green, yellow and orange wires inside the tstat and wire nut them together. Not sure if your reversing valve energizes in heating or cooling but, turn the power back on. If the unit is heating turn the power off and remove just the orange wire and turn power back on. Let this run and see if it you are ONLY getting cool air ALL the time. If so you have a bad stat. If still getting heat possibly you have a bad control board in the air handler. Good Luck!!
Apr 15, 2017 | Honeywell Heating & Cooling
I can't find the summer switch on my furnace model FG6RA 072C-12A
there isn't a summer switch - the thermostat will switch the operation from heat/winter operation to cool/summer operation. I.E. "Cool" for Summer and "Heat" for Winter.
Aug 05, 2011 | Heating & Cooling
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
My dishwasher blinks the green clean light
May have a bad heater. press hi temp, air dry,hi temp, air dry (or whatever button is equivalent on your model). this starts a test and will allow unit to work again. When drying light goes out touch the heater. If it is cold then it may be bad. You will need a voltmeter to tell for sure however.
May 27, 2010 | Whirlpool 24 in. GU2548XTP Built-in...
Only warm air
If its' tank is full of water then empty it. If it is not full of water then the switch underneath the tank may be faulty
Apr 19, 2010 | Pelonis KCD-25YI Air Conditioner
Dryer stops working after 2 minutes into cycle
If it is new, is it not under warranty?
does it run ok on air dry? Is there good air flow?
post your answers in comments
May 14, 2017 | Whirlpool WED9500T Electric Dryer
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Heating & Cooling Logo
271 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
