Question about Dryers
Won't dry I turn on to dry clothes, the dryer never gets hot. It tumbles but I can feel that no heat is being generated.
    President:
  • 1,776 Answers
The problem is most likely a blown thermal fuse or a bad heating element. The thermal fuse should be attached to the duct just inside the back panel. It is about an inch long. The thermal fuse and the heating element should have continuity, therefore they are simple to test with an ohm meter or multimeter. If either component does not have continuity, then that component will need to be replaced. Hope this helped, and good luck.
Posted on Jul 19, 2009
    Sniper:
  • 71 Answers
The most common cause is a heating element failure, i would advise getting it checked, if under warranty check manual for service instructions and replacement parts.
Dryer heats, tumbles but does not dry. Exhaust has heat.
perhaps the washer is not spinning all of it out therefore making it hard for dryer
Aug 31, 2015 | Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Kenmore dryer model 417 won't dry my clothes. It tumbles just fine but it won't get hot.
if it is electric you need a new heating element they can cost around 80 dollars for the string it yourself kind and the pre strung kit cost double that price mabye more . if you are handy i can tel you how to replace the part in detail. I have also written a few time how to replace this part if you look through my solutionshope this helps feel free to write back for more help i would love to assist you
Jun 27, 2011 | Dryers
Dryer is not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | Kenmore Elite HE4 Electric Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Dryer runs but doesn't dry clothes.
hi,check to see if element gets hot,run dryer for 5mins. open door and look at back of dryer.you should see a red glow.or you should feel heat.if not the element needs replaced.and make sure the tumble is tumblering. a dryer can sound like its running,but nothing is really happen.
May 29, 2009 | Dryers
Dryer not drying
Sounds like you have a ventalation problem. The clothes heat up, but without airflow, the moisture remains. First check the hose from the back of the dryer to the wall. Is it plugged, kinked, or restricted? No? Turn your dryer on and remove the hose. Do you feel pressure coming from the back of the unit? No? You need to take it apart and clean the internal airway. If you do feel pressure, reconnect it to the wall and start your dryer. Walk to the outside of the house. Do you feel a fair amount of air coming out? No? There are companies that will clean your vent in the phone book. There are also vent cleaning brushes you can buy at hardware and appliance part stores.
Jun 26, 2008 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
83 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
