Question about Denon AVR2313 7.2 Channel A/V Receiver
Have Denon AVR-2313ci receiver. FM tuner quit working; will tune in 50 MHz steps, on every step "stereo" and "tuned" are lit but no sound comes out whether actual station or not.
Have tried several factory resets, hard power cycles. Updated firmware a few days ago, listened to radio all day yesterday, today it does not work. Figure tuner module is toast but cannot find part number for what needs to be replaced even after downloading service manual, there is no part labeled "tuner module"
  • Nate Nagel
    Nate Nagel Oct 25, 2016
    Great, looks like that part is available although not quickly, soldering is not a problem, based on description of issue is that the likely culprit? thanks!
  • Steve K Oct 25, 2016
    I think that's the best place to try first
    Genius:
  • Denon Master
  • 1,054 Answers
P/n for the tuner is: 943183100200S. It is soldered in, so if you don't know how to solder, then you would need to take it in.
Posted on Oct 25, 2016
  • Denon Master
  • 10,543 Answers
There is no module per se. Tuning is accomplished by applying a voltage to the tuner chip and their associated circuits. It needs to be repaired by a Denon service center.
SOURCE:
I have sound with AM stereo, but "no" sound with FM stereo
Have you connected an FM antenna to your AVR-1907? This is a co-axial socket on the back marked 75 ohm.
Dec 01, 2013 | Denon AVR-1907 Receiver
Using Denon AVR 2803 as an FM receiver
• Insure that the speaker system is working.
try it on other receiver.
• Check to see if there are headphones connected.
• Check if tuned is lit
Aug 12, 2012 | Audio Players & Recorders
Hi, I have a Harman Kardon AVR 300 that I picked up at a local sale. When I power it on, it switches fine to each input except the AM/FM tuner (the preset, tuning, & tuner mode buttons don't seem to...
Hello Sir, Hi, you may try the following
  1. try cleaning the switches
  2. if this does no solve the problem, its the selector circuit. this may be digital, so you need to search the IC that selects the FM mode both with tuning. this is fair complicated.
  3. buy a cheap separate FM tuner, run it on auxiliary input.
Mar 22, 2011 | Harman Kardon AVR 300 Receiver
Denon avr-486 in tuner mode will find station but no sound but works fine with cd player and ipod.
If it doesn't light the 'stereo' and 'tuned' indicators it will be muted unless you select 'manual' tuning.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-486S-Receivers-manual/id/363ag808/t/2/
See the note on Page 30.
Mar 08, 2011 | Audio Players & Recorders
Struggling to get my tuner working on the AVR-3803 - not sure what is wrong. just not getting any sound from the speakers. everything else works
Perhaps you aren't tuning any stations. That would be a good first step toward audio. Install an antenna, too. "Tuned" and "stereo" are indicators there is a listenable station tuned in.
Dec 27, 2010 | Denon AVR-3803 Receiver
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
How to reset the protector circuit in a Denon AVR 3801 unit?
14 INITIALIZATION OF THE MICROPROCESSOR
When the indication of the display is not normal or when the operation of the unit does not shows the reasonable result, the initialization of the
microprocessor is required by the following procedure.
1 Switch off the unit and remove the AC cord from the wall
outlet.
2 Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
3 Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
NOTES:
• If step 3 does not work, start over from step 1.
• If the microprocessor has been reset, all the button settings are
reset to the default values (the values set upon shipment from
the factory).
• Calling out preset stations from the main unit‘s panel.
1 Press the TUNING PRESET button. TUNING
PRESET
FUNCTION 2 Turn the FUNCTION knob and
select the desired station.
TV CD CDR/MD/TAPE RECEIVER
VCR DBS/CABLE
SKIP
SKIP
ENTER
MEMORY
CHANNEL VOLUME
VDP DVD
TUNER PHONO CD
DISPLAY
SETUP RETURN
MENU
SHIFT
SURR.
PARA. OSD
A/B
MUTING
BAND MODE
TUNING
TUNING
2 1
(Main unit)
Jun 11, 2010 | Denon AVR-3802 Receiver
My avr 58oo denon all lights up and seems to do everything that it shoud but no out-put from any channal tried digital,analog
So it's a basic lack of selection of the source. That let's out the amplifiers and speakers.
Let's stick with FM as the source since it can't be conencted wrong or have cabling issues. Does it indicate that it can tune a station by lighting the tuner's stereo indicator? If not, something very basic is dead. I'm wondering what you meant by "seems to do everything that it shoud". What exactly DOES work?
Did it work at one time and then stop working or is this a new installation we're working through?
Jan 29, 2010 | Denon AVR-5800 Receiver
Denon AVR 1910 - no sound from v-aux or tuner
The tuner is the best source for testing audio issues from a receiver since it uses an internal source for audio. This problem could be two separate issues. Check the tuning in the tuner to make sure it is on a station that you are receiving. The newer Denons will not play any audio is the station is not coming in. Be sure your antenna is connected and tune the station to one that comes in clear.
What source is hooked up to the V. Aux? If an iPod it is common that the volume on the ipod is down .
Nov 22, 2009 | Audio Players & Recorders
No sound from my brand new speakers
I am assuming you have tried new speakers on used unit on both A & B choices. Have you tried your new speakers with old 2802? If they work OK with old unit, you have problem with amplifier in used unit. Take the used 2802 to a reputable shop and have it thoroughly tested. Perhaps it is just a loose connection.
Dec 12, 2006 | Denon AVR-2802
Denon AVR2313 7.2 Channel A/V Receiver Logo
265 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
