Garden Logo
F
Frank macherone Posted on Oct 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I adj carb on ryobi bp 42 that is too lean
Jerry Kramer
Level 3:
  • Master 3,933 Answers
  • Posted on Oct 24, 2016
Jerry Kramer
Master
Level 3:
Answers
3933
Questions
Helped
881396
Points
12076
There are two small screws on the carb. One is for the high end and one for the low end. When it is running you can tweek these slightly to get the result you want. Change the spark plug as well.
1helpful
What is the adjustment or how to adj, a single screw carb?
That is the mixture screw. Turn clockwise to get a leaner mixture, counter-clockwise for richer. For initial setting, try with the mixture screw open 1/4 turn. Start the engine and adjust the mixture screw for good running. After it is warmed up, lean the mixture until the engine starts to miss and then turn the screw about 1/8 turn CCW
1helpful
How do I adj carb when too lean
There are two screws on the carb (small ones) one adjusts the low and the other adjusts the high. very slight turns will get you what you need. Always remember where the screw started so you can get back if needed.
Oct 24, 2016 • Motorcycles
How do I adj carb on ryobi bp42 that is too lean
some carbs have a small screw located in the throttle shaft at the lever
there may be a small plastic block that has to be removed first and then a small screw driver to adjust the screw
probably better to get a repair kit or new carby as that setting very seldom changes
How do u adjust a carburetor for a. 1977 ford half ton engine size is 351 Cleveland
air flow vane adj to the return spring.
gas flow adj on front bottom screws ,not too lean. close it down . back off 3 turns. an try.
then the vacuum advance big knobby thing with black plastic an one screw on side of the carb with a vac hose to it. when u gun it .adjusts points firing.
Ryobi BP42 leaf blower will start but will not rev up when I push the trigger - how can I fix this?
Its a lean condition, not getting enough fuel. Check fuel filter and fuel lines. be sure you have fresh fuel. and the carb needs to be adjusted or rebuilt.
2008 qlink 2500cc cf-moto enginescooter non adj.-keihin carb runs lean/burnt-exhaust/valve dealer cant install after mart carb but i can
all carbs are adjustable,float levels can be changed,jets if you can buy new can be drilled out using a hobbiest drill set(approx $14)you can also shim the needle...make sure your carb is clean and you don`t have any air leaks.
When givin throttle dies
if they are not capped with limiter caps
you can try this turn both adj. cw with a small screwdriver until
they bottom out do not force once they stop turning
now back them out 1and1/4 to 1and1/2 ccw
that is the approx. initial setting.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
