Question about Nikon Coolpix 8800 Digital Camera
Lens Error put my mini tripod on to my camera and apparently the legs are not stable enough when I left it on the top of the table. One of the legs gave up and the camera rolled down and fell on the floor, about approx. from 3 ft high. I immediately checked everything looks ok, but when I turned it on to take pictures I'm getting "LENS ERROR" on all settings eg: Auto, Manual, Scene etc.. Is it fixable? If it is...will it cost me an arm & a leg?
    Problem Solver:
  • 11 Answers
Only Nikon can tell you that. Looks like the autofocus lens mechanism broke inside.
Posted on Mar 19, 2008
Is there a Carbon fibre small compact with splitter
Carolyn
-If you are looking for a compact light weight (CF) tripod for video...., that is going to be...., stable & durable (for use with a smaller video camera or a DSLR) & with a mid-level spreader...., I have some bad news for you. They do not exist!!!!!
-You can get a number of tripods that meet some of these requirements..., but not all!!!
-No fear....., it is still possible to get a tripod that is small, light, repairable and with a higher weight capacity and better durability than either of the Manfrotto tripods you mentioned..., but they will not use a mid-level spreader!!!
-Questions for you...., the manfrotto #055CXB has a column that terminates with a flat plate & a 3/8-16" thread. The Manfrotto # MTV502AM tripod has a 75mm bowl mount. Do you use a video head with a flat base or with a 'bowl'?
-If your head has a flat base consider looking at CF tripods from brands such as Sirui (#N2204 or #N3204)..., great value tripod from China..., or products from Gitzo or Really Right Stuff...., (superior products...., and your grandkids will be using them..., but pricey)!!!!
-If your head uses a 75mm bowl mount get the Miller #1501 tripod...., stupidly strong and well supported.
-Bottom line..., with light to mid weight cameras, if you go with a good quality spreaderless tripod that uses 'rotary locks' vs 'quick release' locks...., the leg mechanisms are so superior that you will find that you will get less flex than most tripods with spreaders. They will also be smaller, lighter and allow you to shoot far closer to the ground!!!
Go t a shop that has a good selection of quality tripods and test for leg twist..., you will be converted!!! (note: to test this leg flex..., extend the legs & grab hold of (2) of the tubes near the top 'crown' and then try to move the legs to the left then right...., many will exibit significant flex at the joints!!!!
Jun 21, 2013 | Manfrotto Photography
Hi My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? please help me, it's an emergency. Thanks!
This should be helpful.
Turn the lens to Manual mode (moving to M). Twist the very tip of the lens till it unlocks.
If you twist the lens on the end far enough on the end to the right you will find it "locks". This is what is causing the screeching sound,, it's locked and can't auto focus. Twist the very end to the left till it releases. This fixed it for me.
Regards,
Sean
Jun 09, 2013 | Nikon D5100 Digital SLR Camera With...
Rokinon 500mm for nikon D5100
The filters go on the back of the lens (the end that connects to the camera). If you detach the lens and look inside, you'll see a threaded ring. Simply screw the filter on, similar to how you put filters on the front end of other lenses.
Due to the great magnification ratio of this lens, you absolutely need to have it on a tripod or other stable support. Even the slightest camera shake will be magnified.
The lens also has very little depth of field, so you must focus precisely. Since you're mounted on a tripod, you might want to activate the LiveView feature and zoom in the subject while you focus.
Jul 17, 2012 | Rokinon 500mm / 1000mm F 6.3 Black Lens...
The tripod legs on my manfrotto 3433 slip. the clamping apparatus doesn't have enough grip and just the weight of my video camera is enough to make the legs start sliding down. I see an allen socket...
Hi toolroom347,
There are different clips on the tripod which allow you to adjust the settings for a firmer grip, you also need to extent the gap between the legs of the tripod for a firmer grip, this will help you to set the optimal settings for your tripod which will be fair enough to carry the weight of your camera.
Also a simple solution to stop this slip problem is to carry a small piece of cloth which has guide good grip or a rubber material and then place your camera on it , this will work excellent for a firmer grip.
This has definitely worked for me.
Hope this helps you as well...:)
Aug 26, 2011 | Bogen Communication Bogen Manfrotto 3046...
Slight dent in one leg near base plate,how does the top section come away from base plate for possible repair,leg will not close all the way.
Check out : www.bogentripodparts.com. While I am not that familiar with that model, there are parts available)not sure which ones_ and ther is a video on tripod repair, albeit a different model.
Apr 24, 2011 | Manfrotto (Distributed by Bogen) 055XDB...
My 17-70 sigma lens is shaking while I'm taking videos on tripod!
Turn off the image stabilization (OS) feature of the lens. This is intended to combat camera shake when handholding the camera. It should not be used on a tripod or any other stable platform.
May 19, 2010 | Sigma 1770mm f284 DC Macro OS HSM Lens for...
Using a 70/200 lense with a annon 40D at a football game at night
to get good pictures you have to stay at least at the same speed as the aperture:
100mm - 1/100sec mini
200mm - 1/200sec mini
if you are in automatic mode, the camera says" there is no enough light, the aperture is max (f:2.8 or f:4) so i shut down the speed." and go against the rule. you have several solution:
1 you stay in automatic mode and take yor photos with a tripod.
2 you put your camera in speed pririty, with the good speed, and try not to moove during the shoot (you can put your camera on something stable)
3 you tune up the iso
4 2+3
Oct 02, 2008 | Nikon Lens Hood, Lens Cap for D200
Nikon Coolpix 8800VR Digital Camera
I have heard of this problem and it was sometimes solved by the following...
1. Remove battery and memory card
2. Place a paperback book on a solid surface
3. Bump the camera firmly on the paperback book
4. Reinstall battery and test
Worth a shot if it can save you from sending it in for service.
Nov 19, 2007 | Nikon Coolpix 8800 Digital Camera
Nikon Coolpix 8800 Digital Camera Logo
150 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
