Question about RCA RCD105 Portable CD Player w/ AM/FM Tuner Cassette/CD Boombox
After shutdown, it acts like it has no power. After unplugging for a while, it resets...
    Problem Solver:
  • 18 Answers
The possible cause is our crrent flucktuion maybe the fuse of your device is busted it need to open it to check.
Posted on Jul 19, 2009
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
Tv will stay on for about 10 mins. then turn off and then the red light would start blinking tv will not turn back on intil i unplug tv
It sounds like you are describing high-voltage (HV) shutdown. As a safety feature, if the voltage in the TV rises above a set limit, the TV will shut off to prevent possible x-rays from the picture tube. The only way to reset the shutdown is by unplugging the TV, then reconnecting the power.
This shutdown can be caused by several things. The power supply may in fact not be regulating the voltage properly because of component failure. Your power line voltage may be a little higher than usual and causing nuisance shutdowns. Or the HV shutdown control may simply need to readjusted because components have aged and changed value slightly, also causing nuisance shutdown. The HV transformer may be defective, or the picture tube is going bad.
Unfortunately, it's not possible to say what's wrong without seeing the set to check operation and determine the cause. So I can't suggest anything you might do yourself to fix this. If you want to keep this TV you should let a professional servicer check it over, determine what's needed and give you an estimate. Or you can use this as an excuse to purchase a new TV. Flat screen sets are quite reasonably priced now, and depending on what turns out to be wrong with your TV, it might be more economical to replace it.
Feb 12, 2011 | Toshiba CF36G40 36" TV
Dns-323 automatically shutdown few seconds after startup
had you found a solution ? i'm front the same problem :(
Aug 01, 2010 | D-Link Dns 323 2-Bay Network Storage...
Screen is not working
Assuming there is nothing wrong with your power connections, which you should check first -- remove battery and unplug unit, disconnect peripherals. Then hold in the power button for at least 60 seconds, reconnect to power source and see if it has reset. No guarnatees but it may reset if it was shutdown due to power surge.
Apr 25, 2010 | IBM ThinkPad T22 2647 Notebook
The power light flashes 3 times the pauses, then three times again. No Picture. If I unplug the power and plug it back in then hit the power button it acts like it trys to come on then pops off and fashes...
Thats the error code for Convergence shutdown. You can get the PT53WX53 convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with instructions.
Nov 25, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
"Improper Shutdown" - Printer keeps turning on and off.
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
8. Be patient to let printer run its tests.
Sep 12, 2009 | HP Photosmart C6100 All-In-One Printer
Router cannot connect to the internet.
Turn everything off:
Cable modem unplug the power to the modem if it has a battery remove it.
Router unplug the power to the router
Shutdown any and all computers connected to the router
Turn everything on in this order:
Cable modem wait until all the lights are on but the internet act light
Router wait until the lights goes through it's test cycle and the internet light (wan) is on.
Boot up the computers one at a time after the first computer is fully loaded go to the next computer
Hope this helps
Terry
Feb 27, 2009 | Arris Touchstone 450a (CM450) Modem
Frozen laptop
According to the manual
Using Emergency Shutdown Procedures
If the notebook does not respond to the Windows shutdown
procedure (Start > Turn Off Computer > Turn Off), try the
following emergency shutdown procedures in the sequence
provided:
■ If the notebook is running Windows XP Professional: Press
ctrl+alt+delete. Select the Shut Down button, then select Shut
down from the drop down list.
■ Press and hold down the power button for at least 4 seconds.
■ Unplug the notebook from external power and remove the battery pack.
Apr 14, 2008 | Compaq Presario X1000 Notebook
Toshiba projection tv
Unplug the TV from the outlet for about 30 seconds. This will reset the microprocessor. Re apply AC and power on the TV. If your lucky the set will come on and play. If not, the red light will start blinking again indicating shutdown. There are many reasons for the set to go into shutdown, but one of the most common cause is failure of the convergence output IC`s. If your TV is in shutdown, you will need to find a qualified technician for proper diagnosis and repair.
Nov 23, 2007 | Toshiba 57H81 57" Rear Projection...
RCA RCD105 Portable CD Player w/ AM/FM Tuner Cassette/CD Boombox Logo
82 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
