Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I have a wd-52525 mitsubishi and it is supossed to be 720p but when I turn it on it says its 480i. What part of the tv makes it 720p or 1080p? Please help.......Thanks Paul
  • 64 Answers
You will have to use component inputs for above 480i, and use the FORMAT key on your remote control unit (lower panel in center) to change to whatever you want for resolution. Be sure you have your signal input set to one of the Component inputs via Setup or Net Command (or use Devices on the remote)
Posted on Aug 01, 2009
Onlly playing jn 480i
Roku only supports 720P and 1080P along with the Standard Definition. If your TV only supports 720i, then the Roku won't be able to display 720i but instead 480i which is the standard display that Roku can do on a TV that doesn't support 720p or 1080p
Aug 06, 2012 | Roku XD Streaming Player 1080P Wireless-N...
How do we set the picture to 1080 megapixels from 480i?
U can't just do it on ur own setting like 480i to 1080p when ever u want.No,u only get what ever the tv stations modes they set and send out only.Ur tv have the 1080p mode capability mean ur tv can pickup that 1080p mode.Dosen't mean u can change 480i to 1080p by ur self anytime u want,if the tv station is broadcating tv signal to u only in 480i u get only 480i.
Jun 23, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
HI...HOW DO I CHANGE MY TV FROM 720 TO 1080?
U talking about tv show broadcasting in 720p,u wanted to changed it into 1080p.U can't do this,u only get what the tv stations modes,what ever modes they put out only.Put out 720p u get only 720p,if put out 1080p u get 1080p only.
Jun 13, 2011 | Mitsubishi WD-52525 52" Rear Projection...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
My 1080p tv is showing up 480i and the quality in HD isn't as good. How do i change it back
I have a Pioneer PDPR036G 46inch Plasma TV, Could I add a setter box to make it High Definition?
May 08, 2010 | Mitsubishi WD-60735 Projection Television
My mitsubishi WD-52525 is broadcasting at 480i, is there a way that I can make it broadcast at 720?
Hello!! Well it is possible.. what you would need to do is go to your menu and select settings, then go to video and then select display to make the change, of course just letting you know that it varies depending the tv model so you will need to check your service book, to see if it does support it :)
Jul 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd 57731 1080p
see if there is dust inside blocking it.
Jan 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
159 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
