Question about Panasonic KX-T7633 Corded Phone
Time how do I adjust time on my phone
  • 201 Answers
Re: time
Your phone can be used on different Panasonic phone systems and each one programs differently. You need to determine which system you have (it's not a phone) and find the directions for that.
Here is a link that has time change instructions for many Panasonic systems:
Posted on Nov 19, 2007
0 characters
3 Points
Ring time adjustment
Enter the model of your VTech 5.8GHz system into the search box at to download a copy of the manual.
Jan 06, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
How to adjust date and time free of charge
You did not specify the phone you using.
To set date and time on your nokia phone
Select Menu > Settings and Phone > Date and
Select from the following:
Time - Enter the current time.
Time zone - Select your location.
Date - Enter the date.
Date format - Select the date format.
Date separator - Select the symbol that separates days, months, and years.
Time format - Select the time format.
Time separator - Select the symbol that separates hours and minutes.
Clock type - Select the clock type.
Clock alarm tone - Select the tone for the alarm clock.
Alarm snooze time - Adjust the snooze time.
Workdays - Select your working days. You can then set an alarm only for working day mornings, for example.
Automatic time update - To update the time,date, and time zone, select On. This network service may not be available on all networks.
Jun 30, 2011 | Phones
How do you adjust the ring time for when a call is coming in?
Dec 31, 2010 | GE 29897GE1 Corded Phone
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Oct 19, 2009 | Panasonic KX-T7633 Corded Phone
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
Display contrast - too dark
You should be able to adjust LCD contrast when phone is idle, just use the up/down arrow button to adjust it (don't go off-hook). If you have background music set, the above procedure will adjust the music volume instead. You can turn Background music on and off by pressing <Feature>,2,6 when your phone is idle. Alternatively, you may press <Speaker> 6,0,2 and then use the UP/Down arrow key to adjust LCD contrast.
Dec 11, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Carnt change the time on my phone
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Mar 30, 2008 | Panasonic KX-T7633 Corded Phone
Date/time stamp on answering machine
Set the correct date and time by pressing "time/set." Then, follow the voice prompts. Press "time/set" again. Use "change" button to advance day. Press "time/set" again to adjust hour. Use "change" button to advance hour. Press "Time/set" again to adjust minutes. Press "change" button to advance the minutes. Press "time/set" when finished.
Aug 14, 2007 | AT&T 1480 Phone
Panasonic KX-T7633 Corded Phone Logo
99 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
