Question about Kenmore 24032\24036 Top Load Washer
Model 110.26832690 ser# CF2913096. When it gets to the spin cycle it "hums" but does not spin, any ideas? Thanks
  • Rick Markijohn Jul 19, 2009
    Where do i get a new coupler?
  • 854 Answers
You need to replace the motor coupler. It's easy to replace the motor coupler on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, just lay the washer on it's back. At this point you will see the water pump, motor, and transmission. Remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Now, remove the two screws that hold the two spring clips attached to motor. Unplug all the wires etc. and then snap the metal clips off motor. Lift motor straight up, it should slide right off. Now you will see the motor coupler. Half of the coupler is on the transmission shaft and the other half is on the motor shaft. There is a rubber center connector ring that connects the two together. Just remove the old coupler pieces by prying under them with slotted screwdriver and replace with new ones. Re-assymble the washer and the problem you are encountering should be solved.
Posted on Jul 19, 2009
Spin cycle does not work. Machine only hums when it should spin.
Check the motor capacitors. Wash cycle and run cycle capacitors are different in some m/cs.If these are OK motor winding to be checked.
Now it is ten years old and you are likely to get ball bearing problem. Get an repair estimate and decide which suits your budget.
Apr 06, 2010 | GE WBSE3120B Top Load Washer
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Nov 22, 2008 | Whirlpool LSN1000LW Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kanmore heavy duty super capacity washer does not spin and belt is off and stretched'
There are lots of appliance retailers online. It pays to shop around, but this is one of them that supplies your belt.
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=N&Metal=N&Plastic=U&OneColor=Y&PageSize=15&FirstPart=1
Hope this helps.
If it solves your problem, please rate as "Fixya."
If it is of some help - then "Helpful"
Thanks.
Jun 14, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
