Question about Microsoft Windows XP Professional
Audio device not working.
I have downloaded the drivers, but it is not being installed, to rectify the
  • 805 Answers
Firstly check ur software version compare ur hardware. if no so u cann;t match and not install. and u need raw software.
Posted on Jul 19, 2009
    Problem Solver:
  • 18 Answers
What brand of your machine please be specific of your pc waht model or what brnad so that we can find the solution for your audio device
I have install various audio driver for my laptop (compaq presario c700 - motherboard : intel (r) pentium (r) dual CPU t2390@1.86ghz but still it says no audio device found. I have installed UCC driver...
Folow the instructions here http://devid.info/en/page/device/ and it should help you get a better idea of the identity of your sound card so you can install the correct drivers.
Thanks
May 05, 2011 | Computers & Internet
When i am installingconxtant audio driver it is telling media device not found and not installing
Typically, if you are getting a "device not found" error upon trying to install an audio device driver, there are a number of issues that could be going on at one time.
First: You may have the wrong device driver or version of the device driver for the device intended for. Check the hardware version number and verify on the website of the hardware device (the audio card if it is an independent audio card that is what you are referring to) what is the latest revision of the driver. Download the driver and install it.
Second: If your device is an external audio card, make sure it's fully inserted into the PCMIA slot (seriel port if being used). If so, then accomplish the following procedure: Power down your PC. Remove the Audio Card and reboot PC. Allow PC to recognize no audio card, then shut down PC and reinstall Audio Card. Reboot PC and install with new Audio Driver
One of the two steps above should rectify the problem. If it doesn't, then the last resort is to assume the Audio card is faulty if it's an external Audio card.
If you have an internal Audio card, then there can be a faulty portion on the sound portion of the motherbood, which then would require the entire motherboard to be replaced. But before you result to this, be sure you have the newest Audio driver for the Audio Codec and installed correctly.
Please keep in mind, Conexant is an OEM supported Audio Codec and you need to refer to the maker of the PC itself for driver support. I.E. it may be a Conexant Audio chipset installed in a HP PC. So, be sure you go the manufacturer website such as "HP" for the audio driver support.
Hope this helps,
Jun 26, 2010 | Computers & Internet
No sound device
Hello Friend,
You need to Install Audio Driver for Your System
  • Uninstall if any driver installed Previously by Going to Device Manager on Audio Tab
  • Reboot
  • Click here to Direct Download sp35940.exe (Go to Download page Click here )
  • You are Done...Ready to Use..
OR if not Worked Above go to Following.. >For Vista Drivers Click>Audio Driver XP (32-bit) Link
>Audio Driver for Microsoft Windows XP (64-bit) Link
Hope This Helped you..Thanks for Contacting FixYa..
May 06, 2010 | HP Compaq Presario C500t Notebook
I can be able to play music but the sound doesn't me out of the build in speakers after formating the new Laptop inspiron 1420.Drivers are installed.
it means you did not install the correct drivers for your laptop. I have experienced this before, but its was rectified when I installed the correct drivers.
Make sure the drivers installed is the exact drivers for for your operating system (Vista/XP).
Go to dell.com, look under the page, and select drivers & downloads under "Support".
On the next page click, "Select Model", choose "Laptops" Choose "Inspirion Laptops" then select your laptop model (1420), press confirm and proceed for the download.
Select your operating system (Win XP or Vista) scroll down and you would see "Audio". Select audio and proceed for the download.
Make sure you uninstall the old audio driver from your computer, before you install the new one.
To uninstall the older driver, click start menu, under search, type, "Device manager" and press enter.
From device manager, right click on audio and uninstall from there.
Take care.
Apr 14, 2010 | Computers & Internet
Windows cannot install the modem device on high definiton device
your driver for UAA bus need to be installed THEN only you can install modem drivers after installaion of high definition audio drivers.
Aug 23, 2009 | Computers & Internet
No sound driver working on my gateway notebook pc
Did you check the Device Manager, the audio driver, has it a yellow ? against it or is it OK and enabled? If it is has the MUTE button been ticked?
If it has a yellow ? against the audio driver then the correct audio driver was not installed. Go to the Gateway Support/download page to download the correct XP driver for your model laptop's audio device and install it.
If the sound still doesn't work check Device Manager to see if the driver was installed and working.
Apr 08, 2009 | Gateway MX8711 Notebook
No audio device found
Download Driver Cleaner Pro v.15 from the link. Also, download, and save on your desktop, a clean version of your Sound Card drivers. Run DCPv1.5 and remove all of your audio drivers, plus any possible problem drivers (i.e., if you installed generic drivers to try and get your card to work). After you uninstall, reboot, install your downloaded drivers and reboot again. This should fix your problem, if not please post an update to this thread and I'll continue troubleshooting with you.
Mar 03, 2009 | Dell Inspiron 1525 Notebook
No sound device found
check for devices in "other devices" in Device manager
Oct 22, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
