Question about Kodak Cameras
I have a kodak 6.1 mp camera. it will not turn
I have a kodak 6.1 mp camera. it will not turn on, nor will the lens retract. I tried all the online help solutions and nothing worked. Any ideas?
    Brigadier General:
  • 3,614 Answers
Check the unit battery if it has a charged or has no problem. Better try to test and check it with another battery.
Also connect the camera on your PC and let see if it will power ON.
If the above solution did not solve the issue, you may need to send the unit for repair, it has to be check by a qualified tech.
Hope this helps.
micro
Posted on Jul 19, 2009
Lens won't retract
Lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 07, 2010 | Kodak Easyshare M753 Digital Camera
I geting lens erro 1.1.3.0.0.0
You did not say your camera is 6 MP or 4 MP. But if it is 6 MP then do the followings.
When an error code appears on the LCD, turn the Mode dial off and then turn it on.
If the error code appears again:
Step-by-Step Solutions and Repair tool is available, use the tool to see if you can fix the problem yourself.
Good Luck.
Feb 24, 2010 | Kodak EasyShare One Digital Camera
Camera turns on, blurry screen for a second, then turns off.
There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly.
An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 07, 2010 | Kodak Z8612 Digital Camera
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
DX4330 black screen, retracts and opens on its own
in the event that you decide to buy another Kodak camera, Kodak offers a 25% discount from the Kodak online store since you have a DX4330.
You may want to check out the Z980.
May 29, 2009 | Kodak EasyShare DX4330 Digital Camera
Lens will not retract. camrea frozen my camera will flicker on and off and the lens will not retract. it is a kodak M763, first time this has happened.
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Dec 26, 2008 | Kodak EASYSHARE M763 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Kodak dx7630
turn the lens slightly towards the way it is supposed to retract.
Sep 25, 2008 | Kodak EasyShare DX7630 Digital Camera
Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
Try helping the camera to retract using your fingers while you turn camera off, try also helping lens to full extent if they don't.if you do not succeed in this simple way the camera lens must be taken apart and reassembled at a repair shop.
Jul 25, 2008 | Kodak EasyShare M853 Digital Camera
Cameras Logo
18 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
