Question about Fujitsu fi-5120C
F error the scaner have an f error
  • 14 Answers
Re: f error
See page 25 of
EF is a hardware error:
"Trouble with the background switching mechanism."
Unfortunately that is not very clear.
Posted on Apr 11, 2009
0 characters
3 Points
I download XP driver for N1240U from Canon. Everything seems to work including successful diagnostics check. But, when I try to scan using Toolbox, I get a TWAIN error message. My file system is NTFS....
scan with adob photoshop /import - from - your scaner device/ , it will be correctly, maybe toolbox not working normally, if with photoshop will not be resaults, in control panel \ in scaner and imaging devices see is there your scanner, if it will not be in there, reinstall driver.
Jun 01, 2011 | Canon CanoScan N1240U Flatbed Scanner
Can anybody tell me whats wrong i keep getting scanner error
try uninstall your software for your scanner and reinstall it after restarting your PC
Oct 08, 2009 | Scanners
Convert canon canoscan N640P EX to use usb
please the old scaner programmi is unstoll and you go a run and add a scaner progremme cd instolldrriver orignal and start the scaner is on
just you used the window xp if fouto didate and give a usb cable and use a scaner
Sep 22, 2009 | Canon CanoScan N640P ex Flatbed Scanner
I can not scan with duplex option
You will more than likely have to get it from fujitsu. You can contact them at 866-375-3788. It is the ADF optical unit part # PA03338-D820 and list at $1715.00
Jul 26, 2008 | Fujitsu fi-5750C Flatbed Scanner
According to the manual, it's on the bottom of the scanner. It's a slide switch that should be moved toward the picture of the open padlock.
Jul 18, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Fujitsu fi-5120C Logo
818 people viewed this question
Top Fujitsu Scanners Experts
Mohan Sriraman
Mohan Sriraman
Are you a Fujitsu Scanner Expert? Answer questions, earn points and help others
