Printer continues to say that it is offline
When I delete the job to do done the printer says that it's ready. After I again try to print it again gives the message that the printer is off line.
  • 73 Answers
Try setting printer to default in ;Printers & faxes'. Make sure online is checked under printer properties.
Posted on Jul 19, 2009
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
How to i clear the queue with jobs waiting to print when the printer says printing but is not printing
Try pressing cancel on the printer first. Then, open the print queue by opening the printers folder, and double-clicking the printer icon for your printer. Try to select the jobs there and cancel them. If that doesn't work, turn off the printer, and wait for the title bar of the print queue to say "use printer offline". If it doesn't change on the title bar of the queue, then select "use printer offline" from the file menu of the print queue. Then try to delete the print job. If this still doesn't work, leave the printer off and reboot the computer, then try to delete the print job again if it is still in the queue. If none of these work, remove and then reinstall the printer as a last resort.
Sep 30, 2010 | HP Officejet 5510 All-In-One Thermal...
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click OK.
Step two: - Check the product cable
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
If the menu includes Use Printer Online , click that option.
Step four: - Stop the print queue
Double-click Macintosh HD.
Open the Print Setup Utility folder.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
Step six: - Remove and re-add the product to the printer list
Click the red X to delete the product from the computer.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
Offline problem...won't print
Unplug it and then re plug it in; I suggest USB connection over anything else; don't worry about self install if you already have done so in the past. In the print > hit properties on the icon for bubblejet > go to the ports tab > scroll all thw way to the bottom and click the "USB" checkbox. and you should be good.
Aug 27, 2007 | Canon BJC 2100 InkJet Printer
70 people viewed this question
k24674
