SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
SOURCE: Intermittant trouble with code d 11
Answer
Duet HT®
Duet®
Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
SOURCE: LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
SOURCE: whirlpool cabrio wtw5600xw0 will not spin
I had the power button off so no lights were lit. I also tried it in teh done mode. None of the buttons put it into self test.
My issue with spinning is it will not complete the spin cycle and the lid lock light flashes leaving water in the tub. If I out the machine on drin and spin it will remove most of the water
I also tried the soil level temp keydance to check the console self test and it would not go into that mode either.
Honda Parts.
