Question about Frigidaire Electric Dryer
Valh my dryer model fer641fso wont start when i push the start button it does this low beeping sound bought brand new only owned for 5 months worked fine all day yesterday stopped working last night.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly. OR The start capacitor may have failed and i would not suggest you deal with that as they give out a nasty electrical charge, also check and clean all filters and check your user manual for further advice as your machine should still be under warranty, call the numbers listed in your manual. good luck
Posted on Jul 19, 2009
Kenmore model 84152/94152, 8 years old, started out with3 beeps over and over while running just fine otherwise. Now, 12 hours later, stupid thing started, while not running as in not in use, beeping once...
that isn't a model number and kenmore doesn't make anything so you have to send the full model number off of the dryer,open the door look around the opening where you put the clothes in and send the model number,if it's beeping and starting on it's own it sounds like you have a computer board problem with it but can't help you without the model number.
Dec 31, 2017 | Frigidaire FEQ1442ES Electric Dryer
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Ultrex microwave won't start
hi gud day.did u have a manual to check before to try to operate, or u think the item is ok to use in ur country coz some model & brand have a diff in tecnical power,what HSN or ur unit is stock for how many years?sometimes this the coz of the problem.tnx
Feb 02, 2009 | Cooktops
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
I NEED YOUR HELP
hi tanks for the question you could have a bad motor or something caught in the blower i would check the blower thanks the appliance doc
Sep 26, 2008 | Dryers
Dryer will not start
Sounds like its blown a thermal fuse.Its under warranty if you just bought it.You need to set up a repair while you have warranty.
May 21, 2008 | Dryers
Kenmore Dryer will not start
my kenmore dryer 80 series wont start the start switch just buzzes and the drum does not turn i put a new switch today vacuum it and check all belts they seem fine dont know what else to do
Jan 08, 2008 | Kenmore 73952 Gas Dryer
Brand new Kenmore Front load won't work
It sounds like the plug is mis-wired. The panel works off of 110v but the rest is 220v. If one line is swapped with the ground you will get 110 only.
Jun 02, 2007 | Kenmore 85871 Electric Dryer
Frigidaire  Electric Dryer Logo
391 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
