Question about ECM Giotto Espresso Machine
My single cup portofilter on my ECM Giotto suddendly is pouring more coffee then it should. I'm using the same grind I've been using forever. My other portofilter (2 cup) works fine and still produces the right amount of coffee. Nothing has changed except the single cup is now pouring a watery soup of 2 to 3 ounces instead of the measured 1 ounce in 24 seconds. I've not changed the grind, or the amount of coffee I normally put in the filter. The portofilter does not appear to be dammaged. Any suggestions? Thanks.
    President:
  • 1,618 Answers
How old is the coffee being used? Normally if you change baskets, the grind should be the same, because the single basket has finer and less holes in it than the double basket. The only difference would be the tamp then, since the coffee grinds works great with the double basket. You would also have to use a different volume of water to produce the coffee. To produce 2 ounces of espresso you need about 3 ozs of water,(about an ounces of water will remain in the coffee).
Posted on Jul 19, 2009
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Where is ecm location 2006 holden rodeo has 3.6 v6 engine many thanks
Step 1. Have a good cup of coffee (but not that instant sh*t)
Step 2. Look at the website page you are on more closely, and notice the lack of questions regarding Holdens, and cars in general.
Step 3. Don't take this too seriously.
Cheers, mate.
Aug 08, 2011 | ECM Giotto Espresso Machine
Brand new machine and the pressure gauge doesn't appear to be working, I've made about 10 coffees over the weekend and experimented with the tamping etc. And the gauge has not moved once? Am I...
It could be a faulty machine, what is your grind setting? Make sure your using the dual wall single cup as a test. Set the grind to around 13 and grind your own beans, don't use supermarket bought beans or preground coffee. Both are garbage.
Also if your using the dual wall basket, make sure that you leave the dial guage in the dual wall setting. Then tamp the coffee so it sits roughly 3-5mm below the rim, this is what I have found is best for this unit.
Then secure group head in to unit, press single cup and you should hopefully get a pressure reading, if it isn't going up you are under extracting and your grind is prob to coarse (correct me if I'm wrong), I've found 13 is not to coarse not to fine. Shouldn't feel like fine sand, when coarse but not powdery.
If the gauge does not move in to the grey area your unit is most likely faulty.
Jun 05, 2011 | Breville Fresca BES860 2Cup Coffee Maker
ECM Giotto toggle (power) switch needs replacement ASAP in Seattle area.
i had this happen myself a few months ago, power switch blew, i took the machine apart took out the power switch, and visited a few local electrical component suppliers, its a standard switch but its 2 stage single throw switch, home depot/Lowe's don't carry this type. ended up going to 3 diff suppliers and finally found a commercial supplier that had it connected the new one and now its fine, works better than the old one ever did. just make sure you bring the broken switch with you when you go to show them, most good suppliers can match it and see if they have one like it in stock.
Apr 21, 2011 | ECM Giotto Espresso Machine
ECM Giotto releases steam instead of water from the coffee group
Check the shower screen and diffuser in the head, they might be blocked, if not, check the metering jet at the top of the head(large nut) CAREFUL, make sure machine is off and cool before removing, use a paperclip or pipe cleaner to clear blockage. If not blocked then you will have to check the brew solenoid.
Mar 02, 2010 | ECM Giotto Espresso Machine
Not enough steam is produced to make good froth.
I have one too and what I do is: turn all 3 switches on and while I'm waiting for the "ready" light to come on I go ahead and pour the milk into my frothing pitcher and prep my espresso basket.
After the "ready" light comes on I install my espresso basket and turn the handle to the "left" so no liquid starts coming out.
Next, I take an empty coffee cup and hold it under the steam nozzle and start opening the steam valve until I get only steam instead of a stream of hot water. Once you have steam, close the valve, put your pitcher of milk under the steamer and froth as usual to around 150 degrees.
Jan 21, 2010 | Coffee Makers & Espresso Machines
My cuisinart coffee maker just recently started not using all the water I've poured into the reserve. Up 'til today it was leaving the last two cups in the reserve, but today, out of the six cups I poured...
This is a real problem with these coffee makers, and there's not much that can be done. However, there is a work around: before brewing, just hit the button to brew 1-4 cups. It'll still brew a whole pot, it'll use all the water, the coffee will taste no different, and you can still program it however you'd like. Cheers!
Sep 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Wet grounds
What you see is condensed stem comming out and no water. The pump is not sucking from the tank as ther is an air bubble in suction line. Still want coffe and don't want to clean your machine??? Flick up the lever with no group in place. Steam comes first then nothing. Pump is running and - voila - water comes as air bubble is gone. (Specially the first cup , never the following ones.) Now put back the group and brew your espresso. The machine is full of scale and neds total clean - by hand./// Olev
Jun 13, 2008 | ECM Giotto Espresso Machine
Ecm Giotto
Have you checked the Thermostat on the unit in the tank if it is stuck it will cause the tank to over heat and pop off the steam valve?? there should be some resettable overheat protectors as well. Has the preassure relief valve been replaced as well??
Feb 14, 2008 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
140 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
