I have a computer where the MOBO and CPU went bad and I replaced. The old computer came with Windows Vista installed on it, no CD. Now, Windows Vista won't boot and windows start up repair is activated and ultimately can not fix. How can I get around this? I don't want to loose info on hard drive or purchase Vista. Can XP be installed over Vista??
    Sergeant:
  • 193 Answers
The problem is when Vista was installed on the old pc it only recognizes that pc so you will need to buy a copy of Vista and install it on the new pc. And if you don't want to loose your info you can buy a ide/sata to usb cable and hook it up to your new pc to transfer your old info across. Hope this helps.
Posted on Jul 19, 2009
Compaq Presario C762NR loses Windows Vista Operating System on shutdown.
sure and lots more, why guess? there are test to do.
the VISTA that MS just ended support, so hows that going to work out? not good right? PNP dead and all that? ouch.
HP ended support on old Persario Cnnn long ago., its dead.
why not buy a used pc with w7 for $20? why invest in the dead?
OK H3LL bent to vista we go.... (not me not ever)
who's DVD , order and mailed from HP or did you burn them to DVD-R?>?? we can not guess media ever it must be stated. clearly.
windows load problems are huge. vast ?
does it install if the huge battery (now dead or shorted)
run and load now???????
this is always first, take out the battery, (never seen on this old any good, so get rid of it now)
step 2:
go in to BIOS is next.
then run hdd tests. if the hdd fails , installing vista is a wasted effort
as is installing with a dead coin cell, never seen an old pc with good coin cell, all this old are bad, so replace that first. ITS OLD
so needs one, now. or bios can NOT SAVE OR RETAIN settings.
ever.
if really savvy, run this.
http://www.pcdied.com/brick-dead.html#Knoppix
hdd testing page.
see knoppix OS, live, DVD or Stick ?
run Knopoix, then run DISK
then run SMART then run DISKTEST>
HDD ok now,
ok now load VISTA
and it might go.
(for sure lots over other ways to fail if it overheats
or was never cleaned of line for 10 years.
see dirt here, see why it must not be allowed to over heat
for sure loading any OS there is.
see the heatpipe and radiator here. if that packs up
it can not load windows.
http://pcdied.com/overheated.html
good luck finding old memory that works on a guess.
hard row to hoe there, for sure.. ask
  1. sure run 1 mem stick then try 2nd. 1 at at time (always have 2)
  2. sure clean it
  3. sure take out the bad battery and new coin cell put in.
  4. sure test the HDD first, most this old are now BAD.
  5. sure other causes even a bad power pack or bad mobo or any module plugged in the mobo shorted, can kill windows dead, for a FACT.
Aug 03, 2017 | Compaq Presario C762NR (KN987UAR) PC...
I have an AX4G PRO ,intel 845g 88n10.016 motherboard that is compeletly gone ,is there a replacement for the board. This computer will be if can get to work again only for e-mails and support a l...
I looked on ebay but didnt see a direct replacement for you. Its too bad that the board doesnt work any more. Swapping the board out may not allow you to start up Windows to the desktop. Heres why. When you install Windows it looks at the hardware in your system and installs things like the controller for the hard drive. Once this is done it looks for that controller before it starts the process of looking for new hardware. If it doesnt have a controller it knows it may blue screen to an 0x0000007b error.
Heres what I would look at. Im wondering if your willing to try to repair the board. If the board has the problem that most people have it has some bad Capacitors. You may be able to fix the board by simply soldering new caps in place of the bad ones. If your willing to do this then look at the board and see if there are any capacitors that have bulging tops. If so then replace them and then the board may work again. If not, or you want to just replace the board then you need to find a board that will support your Ram processor Etc. swap it out and (assuming your using XP) try this fix to make your new system work with the old drive:
http://icompute.info/move_xp_hard_drive.htm
theres also another way as well. If you make an Ultimate boot CD 4 Windows then you you can startup the computer to that ubcd4win and within the programs menu there are some registry editing choices that if you go to you will see a program called fixboot. You should ba able to run that fix and it will allow your computer to start. If you can create or have an UBCD4win CD or USB drive then let me know and I can give you step by step instructions for the boot repair. It is simpler to do this than the article above but both could work for you.
Hope this helps... Dale
Apr 19, 2011 | AOpen AX4G Pro (91.88N10.102) Motherboard
I built a computer for my aunt using an Intel motherboard, Intel processor, 2 x 500MByte DDR3 RAM in a Blue Ninja case purchased from Tiger Direct. The computer worked well for more than two years then...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 16, 2011 | RaidMax Ninja Case (RDMXNJACAS)
I recently bought a used Asus a7n8x mobo so I can rebuild my dead xp Pro 462 A Socket system. I am upgrading the mobo to the "delux = A7V8X-E" board and replacing my 2400 athlonxp cpu with a used 3200...
You dont need the drivers untill after windows has been installed....However... If windows does not pick your network adapter up, you will need to load these before you can get online.
Download all the drivers for the motherboard and just Burn them onto a cd as a data disc, so you have them ready
Jul 14, 2010 | ASUS A7N8X Motherboard
Will cloned Hard drive work with new MoBo and CPU
No, it's not true, but you will need to buy Partition Magic to clone the smaller drive onto the larger one.
The new MoBo and CPU might give you more trouble though. All of the windows drivers for the old MoBo will be confused when they see all new hardware. In the olden (WinNT) days, this rarely worked. Now in the WinXP SP3/Vista days, you'll probably be just fine.
Sep 01, 2009 | Seagate Barracuda 7200.9 500 GB ATA-100...
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
Emachines C2825 problem
If you know the motherboard is bad as well, you have two options. You can salvage the existing case and parts, and replace the motherboard and PSU. Plan on spending around $100-150 for both together. This assumes the CPU and RAM are undamaged. The second option is to buy a different "bare-bones" system, and transplant the parts into that one (CD/DVD drive and Hard Drive). Unless you have an exact replacement for the motherboard, you'll probably need to reinstall Windows. The easiest way around this is to install Windows onto a new hard drive, and attach your old hard drive as a "slave" or "secondary". These two options are centered around off-the-shelf parts, rather than buying a "brand X" computer. If you prefer "brand X", which includes an 800 # you can call, look at Dell. eMachines and Dell both produce low-cost low-quality systems, but Dell is better at it. For ideas on parts, look at an online retailer like NewEgg. For compatability, this is mostly a matter of using a tape measure and/or counting pins; they have low prices because they aren't there to hold your hand; if you would feel more comfortable with some hand-holding, which is fine, buy a new "brand X" computer. Lastly, keep in mind, the difference between a $500 computer and a $1500 computer is more than profit margin. If they don't say exactly what a part is, it's whatever was cheapest at the time. A $500 computer may be all you need, but it will have problems like this; whether that's best for you, is for you to decide.
Oct 01, 2007 | Intel D845GVSR Motherboard
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Apr 26, 2007 | Jetway 939GT4-SLI-G Motherboard
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
