Cant open the door on my washing machine
My washing machine HOOVER HP11 1100AA has finished its cycle the timed lock has finished but the door will not open. There is a spring on the back of the handle and when you pull the handle the spring moves a hook, I think this is not happening as the hook is not moving into the unlock position. How can i open the door without smashing the glass?
  • 867 Answers
If you can get a small thin metal object in there and jiggle it around, you may get it open. if not, sheet metal panels will have to be removed to get to there. do not smash the glass!
Posted on Jul 19, 2009
The washing machine has finished its cycle, beeped that it is finished but the red lock button is showing so I cant open the door.
There could still be water in the machine. Clean the filter and check machine is empty. Also it could be the door lock.
Regards Dave
Nov 01, 2017 | Washing Machines
Error code E07 on my Hoover WDYN 854 DB results in me not being able to open door after a wash cycle any ideas how to open door
Switch off and for Door lock fault or Motor fault .
Check both are ok and make sure nothing is jammed or restricting the operation as it is according to which main board is fitted to the machine.
Feb 02, 2015 | Hoover Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Can not open the door on my front loader hoover electra 530
Please check on this link for tips to release the lock: click LOCK
Jan 17, 2013 | Washing Machines
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Jan 19, 2010 | Washing Machines
Door wont open on my washing machine hoover select 1500
I just had the same problem and came here looking for a solution...I went back one last time and tried to unplug. That didn't work. Then I put it on drain/spin and after a minute interrupted by hitting the pause/cancel button - and it released! I am so happy!
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
Washing Machines Logo
510 people viewed this question
Top Washing Machines Experts
