Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Stalls when put in gear or engage mower
My 17 hp craftsman starts and idles good but as soon as I put it in gear w/ clutch fully engaged or attempt to engage mower the engine stalls.
  • 4 Answers
Had same problem is safety switch by the deck causing your problem jump it or replace it
Posted on Jul 25, 2010
    Problem Solver:
  • 13 Answers
Your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Posted on Jul 21, 2009
Craftsman riding mower starter will spin but not engage
The keys are not dropping in the clutch fan. Lightly tap with hammer before attempting to start. Will need to replace eventually.
Dec 16, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
Replace the seat micro switch. Also make sure the block connector is fully pushed home on the micro switch.
Jul 16, 2013 | Craftsman Garden
I have a craftsman 917.287030 and it will not stay running. i put it in gear and it stalls. any ideas??
Check the seat safety switch. For example, start the mower and then engage the blades. If the seat safety switch is faulty, then it will die. Same thing with putting it in gear and releasing the brake.
I hope this is helpful for you.
Aug 22, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It starts but as soon as you turn on the blade or put it in gear it kills the engine
Keep your clutch pedal depressed when you engage blade3 or put in gear.Good Luck!
Aug 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a sears craftsman 6.0 rear tine tiller.
Hi little,
The 7.0 hp version does the same thing.
I found that it was caused by the transmission not being fully engaged to a particular setting. when it tries to engage the tines in both forward and reverse, the engine stalls immediately.
After taking to neutral and back a few dozen times I got a 'feel' for it. Has happened in over a year.
Try it. It did take patience.
Best regards
Jul 16, 2010 | Craftsman Rear Mount Tiller
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,910 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
