Question about LG DLG5988 Gas Dryer
Check Filer i can't use my machine it keeps telling me to check my filter, i have already cleaned it and keeps telling me to check it. The dryer was run without the lint screen in it, so i beleaive that there must be a filter inside the unit that needs to be reset.
  • mruzicka54 Jan 07, 2008
    I'm having kind of the same problem. The "check filter" light is on, I've cleaned the filter, but the light stays on. Seems to work OK but how do I reset te light?
  • Anonymous Mar 02, 2008
    I had the same error code. It says to clean the filter, I did, I've tried to rese the dryer, even unluged the dryer for 30 minutes. Still nothng. When I try to turn the machine on, it still reads "clean filter" any help would be appreciated. Thanks
Having the same problem, but my dryer controls seem frozen and the dryer won't allow me to select settings and proceed with drying.
Posted on Nov 18, 2009
  • 489 Answers
The clean filter light is just a reminder light.  There is no reset button.  It will always come on when you turn on the unit.
Posted on Apr 28, 2008
2 Suggested Answers
  • 3587 Answers
SOURCE: Check Filer lint screen means that you have lint buildups inside the machine...check the air lines, and in and out for the vents..first.
Posted on Mar 15, 2008
What does it mean when it tell you to clean filter and the filter is already clean
That clean filter symbol is just a reminder to clean the filter after every dryer load--I'm assuming this unit is a dryer, however it's listed under washing machines.
Aug 19, 2015 | Washing Machines
Based on just giving the model number 57700 ... I assume this is a condenser dryer from AEG??
If so ... in addition to cleaning the fluff filter ... make sure the water reservoir is totally empty and that the condenser is clean. You may have already checked these. If so ... then the issue could be where ever your sensor is ... and I am not sure where that is
Good luck on your troubleshooting
Feb 10, 2018 | Washing Machines
Cleaning Inglis washing machine IP41003.
Wonderful product on the market called "Affresh" comes in a tablet form. Place one tablet in the basket, and start the "hottest" and "longest" cycle and let it run. Be sure to leave the lid open or up when not in use, and be sure to keep that boot clean. The filter should be removed and cleaned "they say" every 3-5 months, but I tell my customers it depends on how you use and take care of the machine. If you forget to clean your pockets, get coins or pens, or use "smaller" items of clothes without a garment bag, then check more often. Also if you have small or very young children, check more often. Easy way to tell, pull out filter (watch for the water), and see whats in it. If it has a bunch of stuff, check it more often, nothing in it, maybe once a year.
Nov 09, 2013 | Whirlpool Dryers
My dryer keeps saying Lint Filter Problems and cutting off however the lint filter is clean. Because of this issue I the dryer will not stay on long enough to actually dry the clothes. It continuously...
try two things. first, run it empty without the lint filter installed. if it gives you the same error message, install the filter, but disconnect the flexible duct connected to the back of the dryer. try it again. if it still wont work, you will have to get it serviced and cleaned out. if it works with the ducting removed from the back, your dryer duct is clogged up. check your yellow pages for dryer duct cleaning. The lint filter error message is just your machines way of saying it is not getting enough air flow. It can be caused by a clogged duct also.
Nov 20, 2010 | Siemens Dryers
Dryer lights keep flashing after I've cleaned filter and air cooler
check exit of machine and vent tube if ok possible fan motor not up to speed
Aug 30, 2017 | Dryers
My LG dryer will not dry anymore. Lint is only on 1/4 of the lint screen when I pull it out. It takes about 3 hours for one load to dry
First check that the duct is clear of obstructions.
A quick way is to place a wet towel in the dryer, remove the duct from the wall and let the machine vent inside of the house. run it at high heat without the filter screen in.
While it is running check for good air flow by placing your hand near the dryer vent. Also note if there is any heat. also listen for the sounds of the drum turning.
If there is good flow and good heat then the filter screen of duct needs cleaning. Inserting the filter screen and running the test again will tell you which it is. If there is a noticeable difference between filter in and filter out then the filter needs cleaning.
If there is good flow and no heat then the dryer element needs to be checked and either a thermostat or element replaced.
If there is no flow then the blower needs to be replaced.
If there is no drum spinning but heat and flow then the belt needs to be replaced ( Extremely unlikely)
If all of these conditions check out then you will need to call a tech in to diagnose.
Jul 28, 2008 | LG Dryers
LG dryer, keeps asking me to clean filter, I checked the door lint filters & the condencer?? any idea
hi my dryer no longer gets hot enough to dry my clothes without
having to run it for almost 2hrs for one load...this is a big problem..
can someone help me find a answer on model# DC-382WD. I search this model and it tells me it doesn't exist???
thank you,
Apr 29, 2008 | Dryers
Mar 15, 2008 | LG DLG5988 Gas Dryer
LG DLG5988 Gas Dryer Logo
696 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
