Question about Maxtor Hard Drive
Pin settings Can you tell what each set [pair] of jumper setting is used for on a Maxtor 6E040L0
  • shahchin Dec 23, 2007
    I am using same HDD and am having a problem while I boot the computer.
    this message pops out during boot up but after that system works smoothly.
    A problem with the Hard disk has been detected consult the trouble shooting of user manual.
    Please help me .I am using windows XP professional.
    Regards
    Shah
  • 37 Answers
There are four Jumper settings on a Maxtor:
(got it from http://www.techspot.com/vb/all/windows/t-32378-Windows-XP-Home--No-boot-device-help.html)
posted by by mr.smit:
"The 2nd row, is for DS(Master): only 1 drive in PC, or the drive that you want to boot up from.
The 3rd row, is CS Enabled: Cable select, the computer desides wich harddisk is master and wich one is slave
The 4th is cap limit: windows cannot run on harddisks that are to big, like 300gb, so putting jumper on cap limit (capacity limit) makes it smaller for windows to use it.
The 5th row has no use, or i don't know what it does, either of that 2."
I would like to add about the DS (Slave) setting. It is used if there is another drive present on the system which you want to boot from. It will become a spare Hard Disk.
Here is a picture of a maxtor drive indicating where to find model number and jumper settings.
http://xboxdrives.x-pec.com/images/maxtor-drive-model.jpg
Posted on Nov 19, 2007
Please describe the correct jumper settings for the harddrive in the slave mode. Thanks in advance
Right next to power plug are your jumpers referance point is 1 solo pin all the rest are in pairs,on the side should have letters for jumper ma=master sl=slave cs=cable select place your jumper on sl you should be good to go
Jan 08, 2011 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Old maxtor harddrive
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Aug 30, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Maxtor hardrive
If one of the jumpers shorts two pins and the other jumper is a single pin short, remove the two pin jumper. The single pin jumper should be located on the pin at the far upper right corner. should be set as a slave at that point.
May 26, 2008 | Maxtor Hard Drive
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Maxtor HD
The second pair joined (jumper) I suspect it is configured as cable select.
J50 is the left-most pair, and joining them sets the drive as master.
Apr 04, 2008 | Computers & Internet
Maxtor Hard Drive Logo
1,518 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
