SOURCE: UNABLE TO LOG ON TO SLY ELECTRONICS 7" 4GB TABLET
Hold down the power button and the volume up button after shutting it off.
You might need to flash new firmware.
SOURCE: what dose code 10 mean for my proscan 7 inch tablet
It means you will likely have to do a "factory reset." That would return the tablet to "fresh out of the box" status. Yes, you lose what ever has happened since then.
1. Look for the reset hole on the sides of the device. 2. Poke the hole for 5 sec. using a paper clip or a pen. 3. The device will reset. If that did not worked try this. 1. Power off the device. 2. Press and Hold Volume down and Power button at the same time till you see the recovery screen. 3. Use volume down and select Wipe data/factory reset. 4. Press power button to accept. 5. Use Volume down and select YES. 6. Press power button to accept. 7. Press Power button to select Reboot after the reset.
Otherwise, you might have to take it to a shop or send it off and you won't like what that will cost if it is not under warranty.
