Question about RTO Oar Sockets
Lower unit removal on 79 mercury 40 hp
I don't have a problem yet, but want to avoid one. i have to remove it to replace water pump impeller. just need to know the right way, also do you have to disconnect the shift rod in any special way.
  • 154 Answers
You need to remove the pin on the lower part of shift rod, keep all in same location when changing,pretty easy
Posted on Aug 03, 2009
Mercury 9.9 outboard 2 stroke Serial number OD127396
by removing the connecting bolts and shift rod connector
May 30, 2014 | Boating
35 hp mercury
Pices of impeller could be stuck in block,put hand on top of block and feel if it is running hot,blow compressed air into tell tale and see if that helps
May 12, 2014 | Boating
Water pump not working 15hp
Remove lower unit ,remove impeller inspect replace if damaged,these impellers are normally changed at yearly service interval!
check replace gaskets if necessary
Mar 30, 2013 | Boating
1977 9.8 hp Mercury Outboard Motor Serrial # 4605112, it's an electric start with a short shaft
put it in forward gear. Drop the lower off by releasing the bolts and nuts holding it holding the lower on. (one is hiding under the back pick up screen)- some models had a plug in the back top of the exhaust/intermediate housing hiding an allen head bolt pointing down.
Once released, put a protector in a vise and clamp the lower to the bench.
2 screws or bolts will hold the water pump cover on. (the drive shaft runs thru it) Clean the carbon and rust off the drive shaft will allow the pump housing and impeller off the lower. Retrieve the funny looking key drive which runs the pump.
Inspect the shaft, the lower unit oil for water. and find all the pieces of the water pump impeller which may have gone places they shouldn't have.- including the outlet tube from the power head. Check this by putting a tube on the end and blowing- you should hear and feel the pressure in the exhaust and tell tale hole.
Now take the model number , the old pump parts to the marina for a replacement. Do a side by side comparison at the marina so you get the right stuff. Check the inside drive of the rubber impeller and see if they are exactly the same.
NOW- put the new wear plate / gaskets and drive key on, hold in place with grease. Slide the impeller on the key and spin the drive in both directions to be sure it has the impeller and will securely turn it.
Put grease in the cup of the pump housing to prevent dry start and help seat the impeller blades. Spin the shaft as you lower the housing in the pump so the blades all face in the right direction (clockwise). Screw in the bolts. Grease up the seal the watertube goes in and the spline end of the drive shaft.
Up the hole it all goes, now you only have to spline the shifter (it hasn't moved has it?) The drive shaft and the water tube all at the same time.
Check the shifter for correct position and bolt it down
Jul 28, 2012 | Mercury Mark 30 Hipo Outboard Motor...
How to replace water pump on a 1985 90 hp mariner outboard motor
mcdevito75 Here, If I;m not mistaken the water pump is in the lower houseing, a big job, let the marina take care of it as the water pump should be Changed only if it doesn"t pump at all.
Jun 16, 2010 | 2004 Mercury Mariner
How do i change the lower water unit on a 40 hp 2 stroke mercury motot
You mean the water pump? It is fairly easy , You have to drop the lower unit, a long shaft is attached that goes up inside the engine, I haven't done this in a while, I'm trying to remember, I know that the shaft had threads on it, and you had to count the number of turns, to get it to shift right. That was the hard part, change out the impeller, new rubber, new plate, You are all set. If it is the lower unit you want to change out, It is basically the same, but all those parts in there are replaceable. If the bolts are frozen, get some "blaster" on them and let them soak.
Feb 20, 2010 | Bass Pro Boating
Gear shifter for 40 h. p. mariner outboard
With your lower unit off have someone shift the engine into forward while watching the gear shift select shaft's rotation,let gearshift remain in forward,now place your lower unit in forward and reinstall. In the future just put engine in forward when installing a water pump as there won't be a need to move gearshift
Jul 23, 2009 | 2004 Mercury Mariner
Mercury 20Hp impeller/water pump location
It is located inside the lower unit housing. They are fairly easy to replace. Most Mercury authorized service stations will charge around $120 for this task.
Triton72
Mar 26, 2009 | Sport & Outdoor - Others
Maytag dishwashwer problem
hi try this In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Sep 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
RTO Oar Sockets Logo
844 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
