Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice dispenser is not operating. will dispense ice occasionally. noticed the light in the dispenser opening gets dim. Water is dispensing normally.
  • cberstler Jul 19, 2009
    No noise at all. the light in the dispenser opening dims, but nothing happens.
  • GE Master
  • 1,606 Answers
When it doesn't dispense , do you hear the auger turning ? If so , then the dispensor flap is not opening completely . This is caused by a rusted plunger in the solenoid which opens the flap . If you use crushed ice often , then could be a build up in the ice shoot which has to be cleaned regularly .
Posted on Jul 19, 2009
  • Mike Smith
    Mike Smith Jul 21, 2009
    No noise , probably main control board bad . Would have to go into test mode to see if dispensor board is communicating with the main board .
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
Ice continues to be made, about a week ago, the part that turns the ice to crush it or dispense it doesn't work, it also takes about 2 minutes when water is activated before it will finally dispense, all...
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again. It it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Aug 21, 2009 | Refrigerators
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Clicking, no water or ice, power problem?
first i wold check the micro switch that the acuator paddle trips next i would replace the watervalves which is the most likely cause of this finally id replace the control bd as some early ges had a promblem with this there is also a solinoid in there for opening the ice chute door but that wouldnt affect the water but may cause a voltage drop if its getting bad id change the water valves the ice is on one valve the door water is on the other
Jan 19, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Ice dispenser not working - GE side by side refrigerator
Check auger motor if getting power then probably motor gone , if
not may be switch. good luck
Nov 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
306 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
