Question about Miltope TSC-750M Notebook
I am trying to boot from CD with no luck. I have changed the boot order in the bios, still no dice.
  • smich539 Jul 19, 2009
    I changed the boot order now I am getting a "02B0:diskette drive A error.I don't believe this computer has a disk drive.
    Problem Solver:
  • 18 Answers
Try to check your first boot it must be your cd is your first boot then the second is your hard drive then save and exit. try to reboot your machine then hit anykey to your cdrom ok. thanks.
Posted on Jul 19, 2009
I tried to install windows 7 on my HP Pavillion DV9, but it's not booting from CD-ROM, i tried using a USB CD-ROM, but it's still not booting. pls I need assistance.
Try to check if the windows 7 disc that you are using is not just an upgrade disc. Make sure that it is a bootable disc. Try to use other bootable disc to test. Also make sure that the boot device priority is set CD/DVD drive.
Hope this helps.
Jun 06, 2011 | Computers & Internet
I am presently using fedora12.now i want to install windows 7 is it possible,they cannot taken any booting from the cd,by default grub installer is loading
Hi Thanks for your question
In order to boot from the CD drive you must change the Boot Order in BIOS.
In order access BIOS you must press certain key on the keyboard during start up. Depending on the machine it may be F1, F2, F3, F10 or Delete key. Once you acces BIOS you must find Boot order settings. Again depending on machine this may look different, but most of the time it's a separate Tab or settings may be in general part in BIOS setup. When you find it you have to place CD/DVD drive on the top of the list of Boot Order and before exiting BIOS sace changes. Now your machine should Boot up form CD and you should be able to install Windows 7. Do not hesitate to ask more questions if further assistance is needed. Good Luck
May 08, 2010 | fedora Linux Operating System
Want to re-format MSI Notebook S420. Screen continuously shows windows 'loading' but never boots. I have the recovery CD but because the computer never actually starts, I'm not sure what to do with it!MSI
Hello megan_van
While your laptop is on, eject the optical drive and insert the recovery CD. Turn off your laptop via the power button, and turn it back on. The recovery CD should boot. Follow the on-screen instructions to do a clean install.
If the recovery CD doesn't boot, try holding down the C key after turning on your laptop. If it still doesn't boot, you will have to change the boot order in BIOS. Don't worry, this is easier than it sounds! Follow these instructions:
1. Turn on your laptop, and look for a message that says something like PRESS (USUALLY F2, F8, DEL, ETC.) TO ENTER SETUP / BIOS. Hit that key before the Windows logo appears.
2. After hitting the relevant key, you'll be taken to the BIOS setup utility. All BIOS utilities have different appearances, but it is basically a set of menus containing different settings for your laptops hardware. Somewhere on the screen (usually the bottom), is a set of instructions for navigation your way around the BIOS. Follow these instructions to navigate your way to the option for changing the boot order.
N.B. Since every BIOS setup utility is different, the specifics on where the boot order options are located varies from computer to computer. The menu option or configuration item might be called boot options, boot, boot order, etc. The boot order option may even be located in a general menu like advanced options, advanced BIOS features, other options, etc.
3. Once you've located it, use the navigational controls to place the optical drive above the hard drive (usually the +/- keys). To be certain that the recovery CD boots, it's probably best to move the optical drive to the top of this list.
4. Within the navigational controls, there is usually an option to SAVE & EXIT. Press this key. If there isn't, look for a menu option with the heading EXIT. A SETUP CONFIRMATION box will now usually appear asking you to confrm the changes you've made to the BIOS before exiting.
N.B. The SETUP CONFIRMATION box can sometimes be worded cryptically. Read the message carefully to be sure that you're saving your changes instead of exiting WITHOUT saving your changes!
Your computer should now restart automatically, and the recovery CD should now boot.
Hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | MSI MEGABOOK M510C Notebook
I want change my first boot device as cd rom. my system is ibm p3 slot processor
Restart your computer. When you see the first screen you will have 2 options. One is a BIOS setup. It's either F8 or F1. Once you get into your BIOS (screen will be mostly blue). There will be a boot option screen. Make sure you chance the #1 device to CD-Rom.
Sep 22, 2009 | IBM PORTMASTER WITH 512KB 53F2656
I insert restore disk and nothing happens
Hi there.
If you don't have the option of hitting F12 to change the boot order to the CD/DVD just as the computer starts up then you will have to enter the bios to change the boot order.
Restart the machine and hit either Del or Esc to enter the bios, look for the boot order and set the CD/DVD as first boot device, hit F10 and exit the bios, the computer will restart and you should now be able to boot from the CD/DVD.
Please post back with the results and if you need anymore help.
Good luck and thanks for using FixYa!!
May 24, 2009 | E-Machines (T2824) PC Desktop
Don´t boot from CD
You will need to enter the BIOS setup and change the boot order of your drives to boot from CD first.
Good luck!!
Mar 15, 2009 | ASUS Computers & Internet
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
Miltope TSC-750M Notebook Logo
103 people viewed this question
Top Miltope Computers & Internet Experts
David Payne
David Payne
Are you a Miltope Computer and Internet Expert? Answer questions, earn points and help others
