Question about Sunlite Bike Rack Rear Alloy Welded 27/700C
Need installation Directions
Hi just bought a sunlite 45775 rear carrier. Need installation DirectionsANyone know how this goes together?
Sunlite bike cable lock. I opened the lock and now cant put the male end back into the lock because I forgot the combination
Well, the lock is not any good if you don't know the combination, but for a barrel-type combo lock, if you accidentally turned the numbers while open just push the male end in and turn the 1st ring until it goes in slightly. Then turn the next ring and so forth until it's all the way in. Now you can see the combination.
Apr 14, 2017 | Sunlite Cycling
Trying to install Sunlite HD tourer rear carrier #45772. on a Rand 18 speed. There are no holes for front brackets in frame. Do you just drill the holes?
Never drill holes in a bike frame unless you have a death wish. "Rand 18-speed" doesn't tell us much. Most cheapo bike frames have a 'brake bridge' with a hole on the center for mounting accessories like fenders. Many racks can mount with a single rather than double front supports.. Lacking that, call a bike shop or web search for "bicycle seatstay rack clamps" to adapt the rack to attach to the seat stays.
Sunlite also makes a seatpost rack mount http://www.bikebagshop.com/sunlite-rack-mount-seat-post-clamp-p-1146.html?gdftrk=gdfV22203_a_7c1316_a_7c5544_a_7c11461678151 which looks like a more elegant way to solve the problem.
Sep 13, 2011 | Cycling
Just purchased my sunlite lock but the directions where thrown out by the retailer.....how do i set my lock combonation? I have it on all zero's now and it is unlocked...thanks
We just got a sunlite lock and figured it out. After it is unlocked with 0000 and the lock opened, the end spins to a "set" position. Set the numbers you want, spin the end back, and lock will be set to those numbers.
Jun 30, 2011 | Sunlite Coil Cable Resettable Combination...
Sunlite deluxe child carrier...lost instructions
I just received the manual via PDF. Doesn't look like I can attach a file to this, so contact me with your email address. It is for the regular carrier, but they go together the same.
Mar 16, 2010 | Sunlite Bike Rack Rear Alloy Welded...
How do I install a Sunlite 27'' 700c Rear Wheels rack onto my bike??? It did not come with directions
you loosen your axle clamp or bolts. Insert the 2 bottom supports on the inside of each bolt or axle. Make sure its outside of the frame but not outside of the bolts or clamps.then tighten both ends. As for the top it either bolts to where your seat attaches to the seat post or there is a strap. Most bolt down...
Jul 29, 2009 | Cycling
Anyone knows where to buy a cartridge carrier?
Here is a link to the user guide for your printer:
Lexmark 3500/4500 Guide
The installation of ink cartridges begins on page 70.
Thanks for using Fixya.
A Fixya rating would be appreciated.
Feb 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Looking for installation manual
call the carrier dealer they have them.
Oct 03, 2008 | Carrier 38CKC042 Air Conditioner
HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Dec 07, 2007 | Motorola Mobility RAZR V3
Sunlite Bike Rack Rear  Alloy Welded 27/700C Logo
67 people viewed this question
Top Sunlite Cycling Experts
John Egan
John Egan
Are you a Sunlite Cycling Expert? Answer questions, earn points and help others
