Question about GE Profile JTP18 Electric Single Oven
I have a GE JTP18 Trutemp. It seems to be taking
I have a GE JTP18 Trutemp. It seems to be taking a long time to cool down after use. Usually at least a couple of hours. If I open the door it appears to cool off quicker but still seems to be pumping heat.
    Guru:
  • 310 Answers
Sounds like a stuck relay on the control board ... can you tell if the bake or broil element is glowing during this time?
Posted on Jul 21, 2009
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
I used the oven in the house we just purchased (a GE wall oven JTP18 and after I turned it off a fan kept running. Is that normal?
Yes, the program and thermostat calls for the fan to cool the electronics, without that you can loose the electronic boards. Normally the fans will shut off once temps drop to 200 degrees Fahrenheit. Enjoy your new home.
Jul 08, 2011 | GE Profile JTP18 Electric Single Oven
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
I have a ge profile oven and F7 is appearing where the degrees usually appear. Nothing will work on the oven
You have a stuck keypad. You can try pushing every pad several times at random to try and clear it. If that does not work,you have to replace the keypad control.
Sep 10, 2009 | GE Profile JTP18 Electric Single Oven
Can I clean an GE Profile TruTemp oven with soap and Water without ruining it?
Yes, soap and water is fine. You can use any mild soap. Just do not clean with oven cleaner.
Please rate solution
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
GE JTP15 oven shuts off
Mine was doing the same thing all day today. All I know is when it was cool I lifted up a bit on the lower burner an inch or so, and set it down. Next thing ya know, you guessed, it, it's working again...Not sure what's doing it, will keep checking for a solution.
Jun 10, 2008 | GE Profile JTP18 Electric Single Oven
Ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Apr 22, 2008 | GE Profile JTP18 Electric Single Oven
Cooling and/or convection fan
I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
Apr 08, 2008 | GE Profile JTP18 Electric Single Oven
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
177 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
