Spin cycle not fast enough . maximum 1200 speed does not appear to get up to more than 600, empties water ok and does the wash but lacks the oomph to do the spin properly. could it be the brushes? or the dial?
  • 867 Answers
If doing laundry at peak electricity hours, it may be the lower current you are receiving from the power company. this is normal, specially in the summer when lots of ppl are using their a/c's.
Posted on Jul 19, 2009
What causes the water not to spin out of the clothes?
Hi, it means that the machine is not spinning fast enough and pumping the water away. If its not spinning enough then you have to get the machine looked at as its not clicking on in the cycle for it to spin fast enough. You also have to have it set to wash cycle that has a fast spin. If it is spinning fast then you have to look at the pump to make sure its pumping the water away.
Mar 18, 2016 | Washing Machines
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Classixx 1200 wfl2463gb/12
this can be one of two thing the pcb (circuit board) or could just be worn brushes that stops it
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Will not spin fast enough on final spin cycle to
ITS POSSABLE ITS NOT PUMPING FAST ENOUGH. CHECK THE DRAIN HOSE AND MAKE SURE IT HAS NO KINK. IF THATS OK IT MAY HAVE A BUILDUP OF SOAP. RUN A EMPTY CYCLE WITH NO SOAP. IF THAT DONT WORK YOU NEED A REPIARMAN TO CLEAN OR REPLACE THE PUMP.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Spin cycle to slow...
have you tried the filter if it is blocked it will not empty properly. joe
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Heavy Duty Speed Queen top loader, HA 4011-3062, with a slow spin
I have a related problem and I just learned on the net that the Vbelt is supposed to slip in "idle" mode while the water pump will do more work.
It is also supposed to slip slightly while speeding the spinning up so as to not cause motor overload.A kind of half clutch function that allows for slipping. This slipping is controlled by the tensioner.
My guess is that your machine's v belt slips too much and thus does not spin fast enough. You replaced the belts, I would look at the tensioner now.
Feb 09, 2008 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
