Question about Sony PCV-RZ44G (PCVRZ44GKIT7) PC Desktop
Won't boot. do not get anything . Just the sound of CD looking for a disk. NoBIOS (F10-F2) access.
  • Sony Master
  • 805 Answers
Format ur operating system again.
Posted on Jul 19, 2009
Computer won't boot error code sata disk s/n 0F00-136B and many more???
looks like hardware failure.
find out what harddisk exactly you do have in the bios :
- press Del or F1 or F2 during booting, goto IDE devices, look for the model, size (in GB) etc.,
write down (the manufacturer could be: samsung, seagate, maxtor, fujitsu...)
- then change order of boot devices so that cd/dvd-rom drive and /or 3,5 '' floppy drive boots
before the harddisk, exit saving changes (F10 or Esc)
- then get diagnosis program from the harddisk manufacturer's homepage,
copy that to a bootable floppy disk or burn it to a cd-r/cd-rw which must be bootable
- boot from the cd or floppy, run diagnosis tool, both short and long test, what does it say then?
- if hardformat is available, perform one
- might work now, at least the hd will be recognized
-setup new windows installation.
have fun
Source : STAT DISK S/N 0F00-136B
Aug 16, 2012 | Dell Computers & Internet
COMPAQ PRESARIO WON'T BOOT FROM CD
Hello, you are experiencing this because of the Boot priority setting in your bios. Your computer has been set to boot from your hard disk first and so it will never try to boot from a CD when it starts. There are 2 ways to fix this:
1. Go into your bios (usually by pressing F2, F10 or Delete key as your computer starts) and set the boot priority to check CD or optical drives first. Consult your PC manual if necessary.
2. Press F12 when your computer starts, this will bring up a menu to select boot options. Choose your CD drive.
Thanks for using FixYa
Jul 22, 2011 | HP Compaq Presario Sr5550f Desktop Pc
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
Recovery Issues A105-s361. Boot sequence always starts with HDD. Tried F12, tried F2 (bios). Any other way to boot from recovery disk(CD-ROM)!!
There is still a way for you to boot from your CD ROM. Just access or go to BIOS again, look for "BOOT" tab and then set the boot sequence of your computer and the set the first priority to be on the (ODD or CD DVD ROM), just make sure you put the CD ROM option at the first section and to do that, Use the arrow keys on your keyboard and highlight it and then press normally "F5 and F6" further instruction are there any way. Once your done, press F10 and select save and exit, Insert the disc on the CD ROM restart your computer at that time your computer should be booting now from the CD ROM.
Cheers . . .
Feb 09, 2011 | Toshiba Satellite A105 Notebook
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
Cannot boot from cd and run setup
When booting, the writing on the black screen should give you a couple of options akin to
Press F2 to edit boot options or
Press "Del" to enter setup. (bios)
You can use either, but you need to set your CD/DVD disk drive as the first boot option.
May 04, 2010 | Microsoft Windows XP Professional SP2
Toshiba satellite 5105-s607 insert system disk error. Every time put o.s disk in keeps saying same message.
Log into the bios and change the boot order to boot from the CD - it will then boot up your CD system Disk first
As the PC boots - you should see a message to get into bios/setup usually F10, F2 or del key varies buy manufacturer
then look for the bios section for boot order and make sure the CD/DVD drive is set to before the harddrive
Mar 19, 2010 | Toshiba Satellite 5105-S607 PC Notebook
Xps m1330 died
does it boot ?
dead ? cant u even c anything on the screen..?
u can revice it back....if u can go into BIOS immedialty while switching on....
press DEL / F1 / F2 / Ins/ .....any one of this key to get to BIOS
look for the boot sequence...
u can make changes to make it bootable from CDROM / DVDROM
make the 1st boot seq to CDROM
then save the changes to BIOS by pressing F10...save and exit comand can also do it.
then insert the WIN xp install CD in the CD drive and swithc on again...
let it boot from the CD
if it does then u can re-format the disk and install the OS
Feb 24, 2010 | Dell XPS M1330 Laptop
System restore disk for HP compaq Presario 1700 help
hi, you may need to set your laptop to boot from the cd/dvd. you will need to enter the bios and check the boot priority. power the laptop as soon as you power on press either F2 or F10 to enter the bios (you have to be pretty quick with the F2 button). once in the bios look for the heading BOOT or BOOT PRIORITY F5 or F6 willchange the boot order.
hope this helps
Feb 22, 2009 | HP Compaq Presario 1700T Notebook
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
Sony PCV-RZ44G (PCVRZ44GKIT7) PC Desktop Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
