SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
SOURCE: Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
SOURCE: Kenmore 596.73502201 Not cooling. Compressor , fan, seal ok
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
Cooling is poor
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
