Naiko n1003 lcd tv has a fault - no backlight
Unplug from mains, remove back cover, remove rectangular silver casing near the top.unscrew circuit board which should have TDK on it.on the underside of this you will find dry solder, just a general clean of this will be enough. done one today..
Posted on Sep 08, 2009
Cw40t8gw red backlight all the time
Backlight have no color. It is white. the screen of your tV shows that color. Might be of screen fault, or the T'Con board fault. Your TV need a through check up. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts.
Faults possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 11, 2016 | Westinghouse Televison & Video
Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
Apr 20, 2012 | Samsung LA32B450 32 in. TV
Need a manual for Naiko TV model N1003
that problem is usually cause of bad capacitors on the power supply,,It is commonly bulged on the top.
Apr 13, 2012 | Televison & Video
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Dec 20, 2011 | Hisense TL1700 17 in. LCD Television
Black screen
Hello
The backlight is not there. Check the backlight inverter. This is a common fault to most of the flat panel TVs.
Dec 18, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Black screen no sound
Hello
This type of fault occurs to LCD TVs are aminly due to its LCD backlight failure. Check the CCFL tubes for damage. Check the backlight inverter board too. You have to open the tV to do any repair to this fault. You must have sound knoledge in electronics to do this work.OK.
Dec 17, 2011 | Niko OTP-3211W 32 in. LCD Television
I hv got LCD TV hv No picture but have very good sound. While power put on ,it flash & go. What to do? This is for BenQ LCD TV 2680.Back light inverter is avllable? in case needed.
Hello
As you thinks mey correct to an extent. If backlight inverter board has some kind of short with its components, the fault you describes here will occur to LCD TVs, irrespective of Brand and Model. Most of the backlight inverters for any models are available at open electronic spare part shops at your town. Just take the backlight inverter board out from your Tv. It will have a special number printed on it, and should be noted when buying a new one. Remember its connections when you take the boaed out from your set. If needy, mark the positions of connecting wires to that borad on a piece of paper, for reference.
Replace the backlight inverter first. It must solve the problem of your BenQ LCD Tv. OK.
gopakumarg43
Oct 07, 2011 | Computers & Internet
No picture
If we first establish if the tv has actually come on and out of standby. If this is the case, gently press on the lcd with your finger..Is there any backlight showing ? Is there any sound on the TV? If there is sound and no picture and no backlight your problem will be the invertor. If there is no sound, no backlight, the fault most probably is the power supply board, and could be a fuse or capacitors going 'dry' with bulging tops. If there is backlight and sound, the problem will most likely be main pcb or the Tcon pcb (mounted on the LCD rear top middle).
Feb 13, 2010 | Samsung LE22A457 22 in. LCD TV
HAVE NO PICTURE BUT THE SOUND IS OK
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
Jul 08, 2009 | Sanyo Televison & Video
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Electro Med Services...
