Question about Dryers
The tumble dryer is working but not heating??? cleaned all filters and water tank. any ideas???
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. In your case it is better that y ou call in an engineer to test it. Also overloading and blocked filters can cause the thermostat to cut out and they can also go with simple wear and tear. Check your service manual for spare parts etc
Posted on Jul 19, 2009
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the...
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
Mar 01, 2015 | Hotpoint Dryers
Hi i have a two day old beko dcu 7230 tumble dryer the water tank and clean filter light keeps coming on even though they are clean and empty is my product faulty.
not too many dryers w water tank, but the air filter light maybe due to a lack of air movement. If you have replaced an old machine, then your problem may be with the existing exhaust and duct work, you'll need to clean them out thoroughly to know. You may have to go outside or up on the roof as sometimes these also have trap doors that become stuck.
Nov 09, 2013 | Dryers
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
Feb 05, 2013 | Hotpoint Dryers
Hi, My candy CIC60 tumble dryer has stopped drying and the empty water light is constantly on. The timer works. I have cleaned all filter,emptied water, checked for loose wires and I can not see a problem....
Tumble dryers are really not around my neck of the woods however I have studdied them just in case they do begin to show up around here. What turns on the light and kills power to the dryer when the water tank is full? A float switch. I bet that float switch is stuck. Probably something simple like that.
Nov 29, 2011 | Dryers
Hi, My 8kg Hoover Tumble dryer Vision HD stopped working, first a filter care light, so cleaned the filters and now the light comes on but nothing happens. Any ideas? Thanks Matt
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Jan 08, 2011 | Hoover Dryers
My hoover tumble dryer Hnc175 wont heat up,is still working as normal, just no heat, i have cleaned out the filters and still not working
Heating elements can fail. These are relatively easy and economical to replace. The heating element is not necessarily the culprit if your tumble dryer does not get hot, however. There are thermal overload cutouts fitted to many machines. If they fail, the current will not be passed to the heating element. Replacement is again, fairly straightforward.
Tumble dryers will often have thermostats fitted. A heater control one, and an exhaust thermostat. The first keeps the temperature correct. The second, as its name suggests, monitors the temperature of the exhaust (in case the airflow in the machine is impeded) Once again, replacement is not too much of a problem.
http://www.repairclinic.com/Dryer-Troubleshooting
Please look, at the link above, it will show you how to perform troubleshooting. procedures and repair.
If you feel you don't want to do it yourself, please call a Hoover Tech, and get it looked at. Ask for a "Quote" for the repair, so you get an idea of whats what.
Apr 08, 2010 | Dryers
The empty water wanrning light will not go out. I
there is a float switch at the pump that has become stuck, and when this happens, the "empty water" light will stay on and the machine will operate but with no heat. just locate the floating switch and give it a light tap back into its place, this will solve your problem.
should you have any problems you can email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 02, 2010 | Dryers
My tumble drier dont heat up. It works but its
there will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
Apr 13, 2009 | Dryers
Tumble Dryer not getting hot
its your thermostat mate they cost 30quid simle to fit
Jul 06, 2008 | Dryers
Condenser dryer cutting out
Hi
There is typically a thermal heat sensor AND a thermal trip. I suspect the heat sensor is fluffed up too...
Oct 10, 2007 | Bosch Axxis WTL 6003 Electric Dryer
Dryers Logo
539 people viewed this question
Top Dryers Experts
