Question about Microwave Ovens
I have a Whirlpool self cleaning double oven MOD RBD245PDBB SER XK1601011 My problem is that I keep getting the following error code: E6 F2 I am able to clear the code once I depress the OFF key. I'm scared of using the oven at this point because I have no idea what this means. Please help! Please email me at: sierralaura6@aol.com
  • sierralaura6 Jul 19, 2009
    Thanks for your suggestion. However, my keypad does not have a CANCEL button.
    Will anything "bad" happen if I don't replace the control board?
    Please help!
    Thanks!
    Thanks for your suggestion. However, I do not have a CANCEL button on my keypad. Will anything "bad" happen if I don't replace the control board?
    Please help!
  • 3,230 Answers
Check keypad connector for firm connection, Press CANCEL. If error code returns after 60 sec. then you need to replace the control board.
you get the control board from the below link -
http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3767567&diagram_id=109079&&model_id=263203
Good Luck!!
Thanks
Posted on Jul 19, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
I have have a 10 year old Kenmore Hood/Microwave combo built by Whirpool. I'm getting an F6 error code. What is the error code trying to tell me?
F6 —Microwave Relay Failure: Check the microwave relay.
The F6 error code which is flashing on your microwave refers to a faulty relay. However, I would suggest that you first try to run a diagnostic (which you may not be able to, but it is beneficial if it works). Here is how:
The microwave oven may be provided with a self diagnostic routine that can be operated through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door.
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed.
If you want to try to fix it your self, Always remember Electricity is dangerous and should be treated with respect.
Microwaves are very dangerous, they can still shock you even unplugged!!
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
Hope that helps.........
Jul 10, 2008 | Whirlpool Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a whirlpool oven. I ran the self cleaning cycle,let it cool down for a day and ride to open the door. It wouldn't open. I then cycled the circuit breaker and tied again. No good. There appears to be...
sad to say but way too many of us have gotten lazy , even I do at times but self cleanings ovens have always been a problem. the excessive heat required is costly and burns up many elements among other things
Oct 29, 2017 | Whirlpool RMC275PVQ Built-in Microwave...
Need to know how to self clean a whirlpool oven... Model number RF302BXDW it is suppose to be a self cleaner, but does not have a cleaning mode.
I checked the owners guide here:
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203189066.pdf
The cleaning steps are on page 23 of the manual.
Note the comments about using a commercial oven cleaner
("Easy Off" is one oven cleaning product that works well)
One product I find that works well on all oven surfaces is Mr Muscle kitchen cleaner. I have a real hard time finding it in the USA stores. Product image and description Link below:
http://www.mrmuscleonline.co.uk/kitchen
Thanks for choosing FixYa,
Kelly
Jul 17, 2011 | Whirlpool Microwave Ovens
How do I use the self-cleaning function on my Whirlpool Super Capacity 465 self-cleaning oven?
If you just want to run the basic self-clean cycle. First remove the broiler pan and racks from the oven. Next clean any heavy spills up with a non-abrasive cleaner (do not use an oven cleaner). Clean the window of the oven door and the door frame (to the outside of the gasket). Then close the oven. If the oven has a touch-pad, press the Auto-clean pad on the oven followed by Start. The oven will automatically lock and then unlock when the oven has cooled after the cleaning cycle. (I'm less certain of the control settings for the dial type of oven control.)
In order to get your manual you need the full model number of the oven. This is on a plate located behind the storage door. This pdf, http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ca8e028c60d9804f85256a8c00621f04/$FILE/4322089.pdf , gives you a picture of where the model and serial numbers are is on page 4 as well as some of the information contained in the serial number on the subsequent pages.
Once you have your model number, go to http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number. This should let you get the manual specific to your oven.
I hope this helps.
Apr 26, 2011 | Whirlpool Microwave Ovens
Kenwood oven when self cleaning commes up with a f5 error
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Mar 19, 2011 | Microwave Ovens
Pigeon Induction Error E6 occurs
E6 stands for 'Internal Electronic Temperature is higher than normal for 3 seconds', contact service centre.Source: Prestige Induction Error Codes
Feb 16, 2011 | Microwave Ovens
I am just wanting to know how to use the self clean feature on my oven
heatman101
Nov 24, 2010 | Whirlpool Microwave Ovens
I have a GE profile double wall oven. I do not have to owners manual. I know I just press clean to clean the ovens, but how long do I set the timer for?
heatman101
Sep 25, 2010 | GE Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
