Hi i have had advice on my indesit wixe 127 and have been told there is a drainage fault due to f05 and f11 faults flashing, i have looked for the filter previously under the front kick panel and cannot locate it,there is a white plastic tube betewwn the pipes but that is not blocked could you please describe the filter and where it is located as i am thick,thanks
  • paul squire Jul 19, 2009
    hi there, there was a hair clip blocking the pump and has been removed, the pump,propellor looking thing does kick in at the right time but it is still not draining the water at end of cycle, could you please explain where and what the filter looks like thanks
    thankyou
    President:
  • 2,187 Answers
The F05 error is caused bywater not draining or problem with the pressure switch. Some washers may not have filter. To check you need to take the cover off below the front panel. Have water containers ready for the accumulated water. Once you see the filter loosed it up a bit and have the water collected unil it is dreained. Have the filter cleaned and tighten the filter once you have cleaned it out. If yours do not have a filter you can use a hose to drain the water or just collect it straight and have the inside of the washer cleaned. Ensure all the hoses are cleaned
THe F11 problem would point to the drain pump. Open up the panel and see if the wires had come loose or corrosion which may need replacing. Other than that it could be a faulty pump.
Posted on Jul 19, 2009
Indesit washing machine lights 2 and 4 flashing
This will probably be an f05 fault code, this indicates a blocked pump.
Apr 12, 2014 | Indesit Washing Machines
Indesit wixe 127 door error
Most likely have to change the door lock and latch assembly.
Sep 04, 2012 | Washing Machines
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Locate and remove large black fastened to bottom of drum.
Hop[e this helps you.
Dec 28, 2009 | Washing Machines
Fabric conditioner not going
Check the solenoid belongs to that tray.It may struck.
Jul 05, 2009 | Indesit WA 125 Front Load Washer
Manual for Indesit WIXE 127
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Apr 07, 2009 | Washing Machines
Indesit W1E 127 showing fault code - F - 11
This is a drainage problem.First thing to check is the filter behind the kick plate at front of machine.
Please note that there will be water in the system.
Please post back your findings for further assistance if required.
Thankyou for using Fixya.
Jan 24, 2009 | Indesit WA 115 Front Load Washer
Fault f05
F05 means pressure switch jammed on full, firstly check that pump is working and that there is no blockage anywhere,
if it still does not work, then you are going to have to call an engineer.
Hope this helps.
Please leave feedback.
Nov 24, 2008 | Indesit W 123 Front Load Washer
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Aug 11, 2008 | Indesit Washing Machines
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
