Question about Yamaha RX-V1800
RX-V1600 when i turn on no sound or channels display on
Hi, I have a yamaha RX-V1600 and when i turn on no sound came out, and in the display the channels ligths don't turn on, i tried changing the inputs like radio or dvd but nothing came out...
  • 19 Answers
If you are sure that the speaker wiring is correct and connections are good, then:
  • Check the input and output connections are correct for each source.
  • Check that the input mode is not set to DTS or Analog - rotate the input selector to the source and the press the input mode, set it to Auto.
  • Also check that the front speakers to be used are selected A or B (or A+B).
  • If there is an optimiser microphone supplied with this receiver, ensure that it is not still plugged in.
Hope one of these solutions work for you.
Posted on Jul 19, 2009
Power failure with yamaha RXV1600 areceiver
Google yamaha rx-v1700 power problem and you will find that a
capacitor # C4 is failing throughout the RX-V line of receivers. It's
an easy replacement fix but on some earlier models it may be
labelled C6 - the fix post has pics of it and specs - readily available.
Capacitor is a 0.022UF 630v.
Apr 07, 2014 | Yamaha RX-V1600 Receiver
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Aug 11, 2012 | Yamaha RX-V1600 Receiver
When I try to turn up zone 2 the display reads fix. Is there a short or an ohms problem?
Look on page 99 of the manual. It's a parameter you have an option to change to Variable. Fix lets Zone 2 or 3 have a Fixed volume level independent of the volume control on the Yamaha. Variable makes them dependent on the control.
Aug 18, 2010 | Yamaha RX-V1600 Receiver
RX V1600 HDMI outputs not working.Any ideas?
read the guide and call the company they can help !
Jun 09, 2010 | Yamaha RX-V1600 Receiver
Yamaha RX-V1600 shuts down in seconds
Your Yamaha RX-V1600 has an audio output transistors are mounted to a large heat sink which keeps them cool during operation. They are electrically isolated from touching the heat sink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set).
You need to check or replace the transistor that's on the heat sink. Or you may contact a pro to replace it for you.
Mar 14, 2010 | Yamaha RX-V1500 Receiver
RX-V1600 2 clicks but won't switch on
I have the same problem, any resolution on this one yet?
Nov 13, 2009 | Yamaha RX-V1600 Receiver
Hookig up rxv1800
This should put you on the right track...
https://www.hifiengine.com/hfe_downloads/index.php?yamaha/yamaha_rx-v1600.pdf
You'll have to register but it is free to do so.
Login HiFi Engine
Aug 14, 2017 | Yamaha RX-V1800
Yamaha rxv1600
have you any further info on this fault. I have the same fault now.
Dec 20, 2008 | Yamaha RX-V1600 Receiver
Yamaha RX-V1800 Logo
399 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
