Where to put sim card in Samsung Galaxy tablet 4
SOURCE: My browser returns "web page
check the wap settings...
if you are not able to figure it out then contact the mobile operator for wap settings
SOURCE: can i insert sim in samsung galaxy tab. 10.1 ?
There should be a little door on the bottom right of the device that you can insert the sim card.
Open the door, insert the sim with the gold contacts down and close the door.
Here's a video as well!
SOURCE: can i insert a sim
Welcome to Fixya. Yes you can see image below.
Thanks for using Fixya
SOURCE: The sim card is stuck,
Cut up a plastic card like a coffee loyalty card or something that is the same thickness as the sim, and make it the same width as the sim
Before gluing the tip of this card, push it in the slot to engage the release mechanism inside.
Your trying to get the mechanism on the removal cycle where the sim will be closer to coming out.
once that is done put glue on the plastic card tip.
Wipe all excess glue from the flat surfaces. you don't need much glue at all. if you bought strong grade super glue it tends fuse to sim and plastic together. so less is actually more.
let it dry well past the curing time as its better to be safe than sorry, lets face it, the sims not going anywhere and l doubt you need to make an emergency phone call.
then if your plastic card is close to the thickness of the sim card as mine was, it will depress all the sim contacts and come
out with suprisingly little effort. it felt on mine like you should have been able to tap it out in the first place.
SOURCE: my mobicel hero tablet does not read my sim card
Hi, first check whether the card is inserted correctly, if that is right, secondly check if the card reader pins are in place, thrid try a different sim card, fouth, ask the previous owner to insert his her sim card and see what happens.
If all else fails, please seek a phone specialist as ypou mentioned above, its a 2nd hand phone.
